Transmission Wobble
Old Jun 17, 2008 | 12:13 PM
NexTnmE's Avatar
Transmission Wobble
I couldnt find this particular problem. I've read the click and clunk threads, but no wobble threads.
This happens in 1st and 2nd gear under moderate to hard acceleration at 2200 - 2500rpms. Slow acceleration it is fine. I can actually feel motor/transmission wobble. I recently had my tires balanced so I know its not them. I also put filled trans mounts on (about a month ago), and had no wobble. This problem started about two weeks ago, and is getting slightly worse. I put the front stock mount back on and doesnt seem to be any different. I am about to put the rear stock mount back on too, so all will be stock again.
I rarely beat my car, hasent seen redline in about a month. I really dont want to bring it to the dealer and have them say I was beating it. But I'll put it back to stock for now.
Anyone else experience this problem?
Old Jun 17, 2008 | 12:19 PM
SSteveSC's Avatar
i feel it too.. i thought it was my tires being out of balance... which they were just balanced too.. I also have air ride though.. so I dunno wtf it is.. I have solid motor mounts on front and back too
Old Jun 25, 2008 | 10:18 PM
soccer1061287's Avatar
Think back to right before you first noticed the wobble/vibration. What did you do with the car just before? If it was the tire balance, I would as if you have the stock lug nuts? If you do not, you need to take one lug nut and the locking lug off and weigh them individually on a postal scale. These cars are very sensitive to all of the lug nuts being the same weight. I had this problem on my car. I had lesser expensive (ie - cheap) aftermarket wheels and "tuner" lug nuts on the car, and this car would vibrate, then stop, vibrate, then stop (you get the idea). There was like 3 grams difference between the weight of the lock and the other 4 lug nuts. The moment I switched back to the factory lug nuts and locks, the problem disappeared. Hope this helps.
Old Jun 25, 2008 | 10:19 PM
D4u2s0t's Avatar
this engine moves like CRAZY. pop the hood and have a friend rev the car, it literally looks like the engine is going to jump out of the car. get some mounts, and it will take care of that problem.
Old Jun 25, 2008 | 10:27 PM
jeremie's Avatar
put stock mounts on it.
Old Jun 25, 2008 | 11:00 PM
NexTnmE's Avatar
Its not a wobble due to the tires. When I'm cruising at a constant speed, any speed, there is no wobble. Its at all speeds, at certain rpm ranges when I accelerate.
Stock mounts would probably fix the problem. However, the engine would still probably be wobbling, but it just wouldn't be transfered into the car.
I do understand that this engine is not that smooth. I was just thinking that the three solid transmission mounts might have been "too hard" on the transmission itself and caused it to wear or break. I've only had this mod for about 4 weeks now, so I cant imagine that the transmission would go in this short period of time...
Thanks for all the advice!
Old Jun 25, 2008 | 11:01 PM
D4u2s0t's Avatar
i bet it's your filled trans mounts. they probably either softened up, or the "Filling" fell out. i would take a look.
Old Jun 26, 2008 | 12:46 AM
BostonBoy's Avatar
WHERE'S ALL THE CREAM FILLING
Old Jun 26, 2008 | 12:52 AM
BigTizzle903's Avatar
do you still have your warranty?
Old Jun 26, 2008 | 08:13 AM
SSteveSC's Avatar
If this fixes my problem im going to be pissed.. but it sounds like you could be right.. I really hope you are right!! I have one tuner lug and the rest are stock!
Old Jun 26, 2008 | 08:26 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Are you RECENTLY lowered by chance?
Old Jun 26, 2008 | 08:39 AM
Z06vettespd's Avatar
Maybe control arm bushings lower and upper??
Old Jun 26, 2008 | 08:54 AM
SSteveSC's Avatar
air ride
Old Jun 26, 2008 | 11:32 AM
NexTnmE's Avatar
Yes, I am recently lowered.
Old Jun 26, 2008 | 11:34 AM
lewisb13's Avatar
I have the exact same problem. Did you get it aligned?
Old Jun 26, 2008 | 11:45 AM
why not bring it to the dealer?
Old Jun 26, 2008 | 11:49 AM
lewisb13's Avatar
Its alignment issue 100% from the springs.
You have offset caster now a little bit.
Old Jun 26, 2008 | 11:54 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Cause that's gay.
Learn to fix a problem yourself instead of paying someone else to do it or having a dealer keep your car for 8 hours just to tell you that your Cat was clogged and that was causing the wheels to wobble.
Old Jun 26, 2008 | 11:55 AM
SSteveSC's Avatar
^^rofl
Old Jun 26, 2008 | 01:54 PM
NexTnmE's Avatar
Yes I had an alignment the day after I lowered it. Its definitely something in the engine/transmission. Just now coming back to work from lunch I threw a code
Old Jun 26, 2008 | 02:00 PM
lewisb13's Avatar
Has it been doing that the whole time or just recently?
Old Jun 26, 2008 | 02:08 PM
Take it to Auto Zone and have them read the code (its free and takes 2 minutes) then report back to us.
Old Jun 26, 2008 | 02:15 PM
NexTnmE's Avatar
Yeah, my dad has a scantool as well. I think I'm gonna scan it, and if its something about the transmission, I'm putting the stock mounts on. I just cant see how mounts would ruin anything...
Old Jun 26, 2008 | 02:46 PM
I don't think that the car throws Transmission codes... and I HIGHLY doubt that it is transmission related.
Old Jun 26, 2008 | 09:01 PM
NexTnmE's Avatar
The code was 0446 I think? Emission evap malfunction. My dad says thats just the gas cap not being on right or something...so I cleared it and its fine. Didn't have time to put the stock mounts back on...maybe this weekend...
