trouble with NLS help
so I put my wot box in my car and I seem to have this issue were when NLS at high RPMS 2nd to 3rd the shifter just stops in its tracks no grinding if i shift normally clutch in let off gas its fine at high RPMS and NLS and regular shifting 3 to 4 is fine as well so what could be the issue? syncros ? could it be a loose connection with the wot box cause sometimes the cruise control does not want to go on or clutch switch maybe?
Who needs a wotbox to nls? I just do it.
Either way maybe try shifting a little slower |
I put the wot box in for 2 step but it has a NLS feature and its suppose to be easier on the trans cause it cuts the load for a second but shift slower doesn't that kinda defeat the purpose of NLS
try little harder next time =P
Please post help answers thanks
Look at the n2mb software and send them an email for help. There's a valuve you can change hat after when you hit the clutch, it will do it's job and let you NLS into the next gear.
Yea I set it to auto it feels the issue is mechanical like the shifter moves to 3rd but stops and wont go all the way in if shove it hard into 3rd i feel i could snap the plastic clips on the cables could the cables need adjusting i dd put in a short shifter but like said normal driving its good
and normal race shifting it good |
