trouble with NLS help
Old Aug 24, 2015 | 08:15 PM
The Rookie24's Avatar
Exclamation trouble with NLS help
so I put my wot box in my car and I seem to have this issue were when NLS at high RPMS 2nd to 3rd the shifter just stops in its tracks no grinding if i shift normally clutch in let off gas its fine at high RPMS and NLS and regular shifting 3 to 4 is fine as well so what could be the issue? syncros ? could it be a loose connection with the wot box cause sometimes the cruise control does not want to go on or clutch switch maybe?
Old Aug 24, 2015 | 09:42 PM
Who needs a wotbox to nls? I just do it.
Either way maybe try shifting a little slower
Old Aug 26, 2015 | 05:46 PM
I put the wot box in for 2 step but it has a NLS feature and its suppose to be easier on the trans cause it cuts the load for a second but shift slower doesn't that kinda defeat the purpose of NLS
Old Aug 26, 2015 | 05:59 PM
kingofpoland's Avatar
try little harder next time =P
Old Aug 26, 2015 | 06:47 PM
Please post help answers thanks
Old Aug 27, 2015 | 02:37 AM
Sl0wbaltSS's Avatar
Look at the n2mb software and send them an email for help. There's a valuve you can change hat after when you hit the clutch, it will do it's job and let you NLS into the next gear.
Old Aug 27, 2015 | 09:18 PM
Yea I set it to auto it feels the issue is mechanical like the shifter moves to 3rd but stops and wont go all the way in if shove it hard into 3rd i feel i could snap the plastic clips on the cables could the cables need adjusting i dd put in a short shifter but like said normal driving its good
and normal race shifting it good
007Buff
Jun 11, 2017 03:04 PM
Bluelightning
Nov 11, 2015 02:41 PM
Hugger1975
Oct 15, 2015 03:28 PM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
