Where to get Clutch alignment tool?
Old Apr 3, 2006 | 03:12 PM
ENUFPWR's Avatar
Well, I have a Stage 3+ Clutch going in my car as I write this, but Spec didn't ship an alignment tool. I called Spec and they said they don't have any that ship with the kits.
Where can I get an alignment tool? My local dealership said they don't sell them. Any advice or part numbers would be appreciated.
Thanks
Old Apr 3, 2006 | 03:17 PM
distillion's Avatar
wats the tool used for???
Old Apr 3, 2006 | 03:26 PM
max_boost's Avatar
You aren't the only one to be asking that question. There was just a post on RL forums about it. http://tinyurl.com/pjxhf
WopOnTour said a universal tool should do the job.
How's the install going so far? I was suprized at the size of the disc, I expected it to be much bigger and it's not very thick either.
Old Apr 3, 2006 | 03:31 PM
Brian MP5T's Avatar
It centers the Clutch to the flywheel when attaching the pressure plate so it all goes together nice and neet.
Old Apr 3, 2006 | 03:50 PM
ENUFPWR's Avatar
Well at the point we are at the point where we need the tool to put the clutch on and center it. I called both Spec and Clutchmasters and nobody has a tool they ship with the clutch's.
They did say an s10 or Camaro alignment tool should work since the splines are the same. All they do is put tape at the end of the tool.
Old Apr 3, 2006 | 03:53 PM
distillion's Avatar
is that what people here have been doin?, some people have aftermarket clutches installed, what was done for them?
Old Apr 3, 2006 | 04:34 PM
ENUFPWR's Avatar
Exactly.... what has everyone else done or used when they installed the new clutch?
Old Apr 3, 2006 | 04:56 PM
SilverSS/SC's Avatar
Man , that is some BS ....seeing as how almost everyone advertises the Spec clutches as coming with the alignment tool . Im doing mine this weekend , hopefully my F-body tool will work .
Old Apr 3, 2006 | 04:59 PM
Cobalt30's Avatar
try calling autozone or pep boys or something like that and try to see if they have some for borrowing.
Old Apr 3, 2006 | 05:03 PM
ENUFPWR's Avatar
That was one of the first things I did and no luck.
I'm going to stop in to a dealership tommarow and see if I can borrow their tool for an hour which is mostly unlikey, but it's worth a try.
Old Apr 3, 2006 | 05:12 PM
Dont forget to try the SAAB and Saturn dealers too .
Old Apr 3, 2006 | 05:19 PM
Cobalt30's Avatar
I would think that you would have better look at private garage then a dealership. You could always leave ur liscence for collateral. Hopefully they'll be cool bout it tho.
Old Apr 3, 2006 | 05:39 PM
max_boost's Avatar
Did you try asking Rob or Intense what they are using to do the clutch installs?
Old Apr 3, 2006 | 06:33 PM
Brian MP5T's Avatar
Holy Crap, It's a $2 tool that comes with the clutch, Relax Guys..
Old Apr 3, 2006 | 06:36 PM
He said spec or clutchmasters didnt include one , and could not supply one
Old Apr 3, 2006 | 06:46 PM
Brian MP5T's Avatar
Did you look on E-Ghey?
I got one for the 944 for $0.50
Old Apr 3, 2006 | 08:20 PM
ENUFPWR's Avatar
Yup, Rob told me he installed it using a socket and extension. I just want to make sure we do this correctly the first time. It's not about the cost of a cheap tool, but about doing it correctly. Ya, and I did check out E-bay....no luck..hence the reason I posted on here as a last resort to ask if anyone else knew something we didn't before we went that route.
Why take a risk and screw up a $600 clutch because you didn't use a specific cheap tool. It just sucks nobody seems to have one available, yet advertise them as coming with the clutch kits.
Ohh well, I guess we will have to go the Camaro alignment tool route or like Rob said... socket and extension to align it all up.
Old Apr 3, 2006 | 08:22 PM
max_boost's Avatar
I agree that does suck. They charge enough for the discs it should be included.
Old Apr 3, 2006 | 08:31 PM
FAST06SS's Avatar
Guys,
Iv'e installed a few clutches in my life so i was skecptical as well. I called spec and was told the design used on the cobalt doesn't need an alignment tool!
Well he was right. The way the input shaft is on the transmission, only a rough "by eyesight" alignment is needed. The transmissions slides right in with no trouble at all! The input shaft has a nice taper to it and filing the grooves in the clutch helps as well.
I have had harder times when i've used the correct alignment tool getting the old muncies and T10's installed
Don't make it harder than it needs to be!
Old Apr 7, 2006 | 10:32 AM
ENUFPWR's Avatar
Well, we followed Rob's advice and the clutch went in smoothly. Thanks
We used a socket and extension to line it all up. Very easy....
We had to adjust the shifter cables after the install which was pretty easy.
Clutch pedal feel on the Spec 3+ was almost like stock with a little bit stiffer pedal feel. The pressure plate sure bites..... and the clutch grips great. I put 500miles on the clutch and then started to get on it. This thing grips, no slipping and chirping gears on every shift.
Feel like I regained another 50hp..lol.... but it's just because my stock clutch was slipping. The difference is amazing.
Old Apr 7, 2006 | 02:25 PM
blown_06's Avatar
i had the same problem with my spec clutch. i took mine to the dealership and had them install it.
Old Apr 12, 2012 | 09:07 PM
AARON-SS-TC's Avatar
so you dont have to have the tool to align properly?..it just makes it easier i guess?
Old Apr 12, 2012 | 09:11 PM
LS6Rally's Avatar
holy 6 year old thread....
Old Apr 12, 2012 | 09:19 PM
TurboTechRacing's Avatar
I would NEVER attempt to install a clutch kit without one. Alignment of the input shaft on the tranny, to the clutch disc would be a pain in the a$$.
KY clutch kits come with them for free.
lol x2
Last edited by TurboTechRacing; Apr 12, 2012 at 09:19 PM. Reason: Automerged Doublepost
Old Apr 14, 2012 | 11:18 PM
09CobaltSS1's Avatar
lol x2
KY's alignment tool is awfull unfortunately. I had one hell of a time trying to align the input shaft to the clutch with the stupid thing, and it still feels like it's binding a bit....
