Will my SPEC stage 2+ clutch work on my new SS/TC
Old 10-14-2011, 04:05 PM
WPG SS/SC's Avatar
I totaled my 06 SS/SC 2 weeks ago (before I had a chance to install my SPEC Stage 2+. ) I have called SPEC but they were not all that informative - Just said it will not work because part number has a dash at the end of it, but gave no reason as to why it wouldnt work. I know that the TC clutch can be an upgrade for the SC, so why will my SPEC clutch for the SC not work on my TC? Anyone know the answer? BTW Im not implying it will work at all just really trying to find an answer as to why it wont work.
Old 08-10-2013, 08:22 PM
linkinsplita's Avatar
Hey, Just curious if you found out any solid info on this situation. I'm in the same boat and would love to use the stage 2 I bought when i had a SC for my now LNF as well!
Thanks in advance.
Old 08-11-2013, 12:39 PM
blueLNFftw's Avatar
I did a lot of searching and reading about clutches when I swapped clutches in my SC and nowhere did I read that you could swap between SC and TC.
Old 08-11-2013, 02:12 PM
09CobaltSS1's Avatar
The lsj and lnf clutches are identical. The only real differences are in the flywheel and stock tob. The lnf tob is an upgrade for the lsj and will bolt right up. The flywheel however is specific to each of the 2 engines so they can not be interchanged. The clutch assembly itself has no difference and can be bolted up to either the lsj or lnf.
Old 08-11-2013, 02:13 PM
Omiotek's Avatar
^^^what he said
Old 08-11-2013, 02:44 PM
Thanks guys. Much appreciated!
yellowsupercharged06
09-17-2015 04:40 PM
ashalle2
09-16-2015 10:36 PM
CobaltSS 16
09-12-2015 02:43 PM
Sean Cummings
09-11-2015 09:35 PM
Jacque8080
09-09-2015 09:21 PM
Quick Reply: Will my SPEC stage 2+ clutch work on my new SS/TC
