ZZP is selling F40 kit again.
Old Feb 3, 2016 | 02:30 AM
Sl0wbaltSS's Avatar
Thumbs up ZZP is selling F40 kit again.
F40 6 Speed Conversion Kit - Transmission & Drivetrain
Old Feb 3, 2016 | 03:03 AM
Devin86's Avatar
Yeah seen that the other day. f40's are loke 800 on ebay not bad.
Old Feb 6, 2016 | 12:52 AM
firehawk618's Avatar
That's crazy money for the kit. I know they surely put lots of R&D into it and will probably only sell a few dozen of them but damn!
That said if my 5 speed takes a dump I might just go this route.
Old Feb 6, 2016 | 12:57 AM
Question that almost immediately pops into my mind.
Are there any F40's that work with this kit that came with a factory LSD? I don't believe the Regals did.
Old Feb 6, 2016 | 02:14 AM
Sharkey's Avatar
no i dont believe any f40 came factory with an lsd.
Old Mar 4, 2016 | 03:10 PM
Jacque8080's Avatar
Could you use your F35 LSD?
Old Mar 4, 2016 | 03:24 PM
zeeky420's Avatar
Can't you just get a f40 transmission and put it in cobalt I seen new1 for 500 bucks then you just get cables and shifter new clutch
Old Mar 4, 2016 | 03:59 PM
Scythe_Snake's Avatar
No, the F35 Quaife does not fit in the F40
No, there is definitely a reason we sell the conversion kit. It doesn't just bolt up.
Old Mar 4, 2016 | 07:02 PM
63 Nova SS's Avatar
Originally Posted by firehawk618
That's crazy money for the kit. I know they surely put lots of R&D into it and will probably only sell a few dozen of them but damn! That said if my 5 speed takes a dump I might just go this route.
Think about it though- it comes with a shifter, trans cables, and axel, trans mounts, flywheel and clutch. If you had an older cobalt that needed cables, mounts, a shifter, and a clutch with flywheel, how much would all that set you back? I don't think it's a bad price. If I had a big turbo I would totally buy it.
Old Mar 5, 2016 | 02:39 PM
LNFwagonSS's Avatar
If you want LSD for the F40, add $1100 for the quaife diff alone. Need 2 new diff bearings and I would also recommend axle seals. Sooooo if u install diff yourself add 1200$ to total cost.
droppindboost
Feb 3, 2016 06:09 AM
SStevie
Feb 2, 2016 09:53 AM
LNFwagonSS
Jan 18, 2016 03:36 PM
BA89
Jan 6, 2016 10:48 AM
