Dyno Results Dyno pictures, videos and dyno results.
09 SS/TC Sedan with 123K
Old Jul 28, 2013 | 09:18 PM
GeforceXtreme's Avatar
Got my 09 SS/TC onto the dyno today for the first time. Proved to me that my locked Trifecta tune that my car had prior to my ownership doesn’t appear to be cutting it with the mods I have put onto it since getting it. Too much air now and not enough fuel. It appears the car is running too lean (13.5 AFR) being others have told me with my mods I should have been able to put down over 300whp? Another tuner of these cars suggested I should be in the mid 12’s range for AFR? I am still happy with what I saw it just now I have to get the ball rolling on getting my PCM unlocked so I can use my HP tuner to fine tune the car with the current mods. Also while on the dyno could smell some clutch so I suspect that won’t be lasting forever. But with 123K I can’t really complain.
Car put down 292WHP/315Torque
Old Jul 28, 2013 | 09:23 PM
cluelessk's Avatar
Numbers look a little low for mods but would still be a blast.
Old Jul 28, 2013 | 09:29 PM
alerosaint's Avatar
yeah your a/f is off.....a good hptuner tuner should should be able to correct it and help bump up the powah! still pretty good numbers for 123k. Makes me feel good about pushing power at 108k
Old Jul 28, 2013 | 09:32 PM
Ideally what AFR do these LNF's like?
I own an HP tuner its just currently my PCM is locked. But I am hoping 1 of the 2 GM dealer sources this week can hook me up flashing my PCM back to stock so I can start manually tuning it myself.
Old Jul 28, 2013 | 09:33 PM
mkulrey13's Avatar
Since adding mods did you have trifecta retune??
Old Jul 28, 2013 | 09:59 PM
Terminator2's Avatar
0.86-0.88 pe lambda or 12.6-13.0 a\f on gasoline.
Old Jul 29, 2013 | 02:20 PM
09CobaltSS1's Avatar
^This....
Keep in mind that most tailpipe sniffers tend to run a few tenths leaner than what you're actually registering at the wideband further upstream by the turbo. So the 13.2afr you're showing in the graph is realistically probably closer to 12.8afr, which is right about where it should be for a lnf. As far as power numbers being low, it's really only relative to the dyno you run on. You can only base dyno numbers on gains, not just peak numbers.
Old Sep 2, 2013 | 08:36 PM
DirtyBalt09's Avatar
this I was gonna say right in there at 12.6-12.8
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 27, 2015 08:53 PM
metroplex
Sep 27, 2015 07:48 AM
