all turbo set up 504whp on pump gas
nastyfastnx on the dyno at zzp 11/16/11 - YouTube
504whp on pump gas 28psi
no stats yet on race gas dyno tuning
what injectors/fuel setup are you running. those numbers are rediculous for pump gas haha. my 80s only took me to 443@20psi on the pump gas. they'd go static about 7,300rpms. so thats 700rpms i'm not using. but i was on 80s, brfps, pump rewire, upgraded pump, with holes drilled in the canister.
80's,zzp fuel pump, zzp fully built motor, stage 2 turbo comp cams, boost reference, rewire kit, maf adjustable adaptor, turbo tech intake manifold, bullseye 259et, .55 exhaust housing and so much more
hmm. you're on the exact same setup i am save for the turbo i'm runnin a billet 262. if you're doin 502 on the pump gas i would expect atleast 650 on the race gas. my race gas tune did 591whp/477wtrq so you should be sittin pretty if you're already at 500. granted you're running 8psi more than i did on pump. but my race gas numbers were at 30psi. damn i need some 198s. hahaha
ya... well i already had most the parts just had to swap over to the lnf alternator and belt system and few other small things bout 2k including the powdercoating,tuning and all
so you do have a ported head? or were you saying ya to the other guy
https://www.cobaltss.net/forums/feat...y-11-a-253216/
yeah, thats the one thing i don't have. i think with a ported head and the 198s i'd be mid 500s on pump and hopefully mid 700s on racegas, cause then the only difference between my setup and ryans 898 setup would be the turbo hahah. i'm only 4mm behind him
i got a trick up my sleeve though
car looks great though man. congrats on the numbers
