D-Rob's 2nd Dyno Bye Bye Stock w/numbers
Went back to the dyno last Saturday. This time with a Injen Intake, Bad Mab Header, a Corsa Performance Touring Exhaust and some 42# Injectors.
Tuning was done by Arthur at Trackmasters Dyno in Huntsville, AL. As usual with me, I'll make a video lol. I was honestly disappointed in the peak gains, which is dumb in a sense, because I'm am most certainly making at or above stage 2 numbers on the stock pulley. I just thought I'd see more over my stock dyno peak. Nevertheless that doesn't really matter, under the curve the gains were huge, and the car (after the tune) is so much faster it's beyond description. It's faster everywhere, it feels like I raised the boost faster, my brakes are begging for mercy after a 3 second wot faster, and that, is real nice. :twothumbs Cooling mods will be in tow, because at the end after placing the fan on the supercharger for less than 8 minutes, I pulled out 5 more hp on the last run. 25 degrees total timing, 7250rpm limit, abuse management turned off. Final number 236hp (235.99, I rounded up) & 204lb/ft. New Dyno http://i841.photobucket.com/albums/z...423/DavidR.jpg Comparison Dyno Plot http://i841.photobucket.com/albums/z...23/DavidR2.jpg Over 20hp & 48lb/ft under the curve. |
Damn that is tight and thats only intake and exhaust right
Thats a nice torque curve.
Great number increase on just those mods! Do you plan on doing a pulley down at some point?
Originally Posted by Vetteman99
(Post 5785193)
Thanks WSox33!
Originally Posted by 1AJeremyD
(Post 5785204)
I pretty much had the same idea as you with going about modding. Leaving the pulley last and doing everything else first (intake, exhaust, injectors, cool and then pulley down if i feel like it later)
wow!!! thats great!! how much did it cost to get that tuning?
Originally Posted by Black Napkin
(Post 5785606)
what kind of dyno? i dynoed my car on a mustang awd dyno with stage 2 kit , megan exhaust and intake and i only hit 185whp. is your 236 crank hp or whp? either my cars f*cked or the dyno i used is at 25% lose from crank to wheels .... :bye:
haha godamn these numbers make me glad i bought a ss/tc lol sorry guys
lol. numbers are okish..... Not saying anything bad.... And im not promoting myself by no means..... But i am close lol.... Just simply saying im close hahahaha
im thinking its the dyno cause my buddy when he dynoed his 08 sti whp was 210 and my other buddys 09 evo mr dynoed at 220whp some disguisting drops from crank to whp or the dyno needs to be calibrated . anyone have issues with awd mustang dyno?
I dynoed 251 whp on ZZP's mustang dyno but it's not a awd dyno. My mods are 2.9 42#'s ZZP Custom tune I purchased their stage 3 FMIC before I left my intake temps were a little high but nothing dangerous had zero KR.
Originally Posted by MaGNuM16
(Post 5791446)
(Post 5791474)
Originally Posted by Chevycobaltss3
(Post 5791503)
Boltons do alot when tuned for them...
235 to me is still low. Because tou could be running tons and tons of timing. Did u check ure ic pump and s.c coolant lines for bubbles.
Nope, I didn't check for bubbles. 25 degrees total timing. I expected more given my base number and my setup too.
Yeah how much timing was added throughout the whole map. And he could have leaned u a lil as well.
looks good, but compared to a GMS2 your tq is lacking a little bit, essentially boost=tq
Originally Posted by RooTBeeR
(Post 5794168)
(Post 5794155)
still definitely better than stock!
