Lnf stock turbo numbers
1 Attachment(s)
Just curious to see I got mine on the dyno and the numbers were a lot higher then I was guessing so just seeing what others have with similar mods
Hahn catless dp, exhaust, CAI, charge pipes, trifecta tune 22-23psi. For some reason it won't let me post the pic of the sheet but hit 328/394 |
Nice numbers I hit 328 418 with a CAI and catless dp on e47 at 4000' elevation
OP what fuel 91 octane? I would love results similar to yours.
Pretty good numbers
That dyno graph dont look too bad for a remote tune |
Seems a little high for trifecta, what dyno was it?
in before hp tuners butthurt. |
What gear
Originally Posted by m33pm33p
(Post 7359596)
Nice numbers!
I hit 320 whp 420 wtq on 24 psi. |
Da fuq
I hit 310fwhp and 380 ft lbs @ 26 psi 91 Oct @ 6000 feet elevation Although it was done in 3rd instead of 4th gear. Gotta do some logs and adjustment anyways :) |
Originally Posted by brianhud1991
(Post 7359864)
Da fuq
I hit 310fwhp and 380 ft lbs @ 26 psi 91 Oct @ 6000 feet elevation Mine seem a little low My power band is better with Terms tune but on Trifecta I hit 312fwhp and 375ft lbs on 23psi tune, 91 Oct. Of course they were different dynos but both dynojet with SAE I have a simliar tune as you and I hit 320 whp 420 wtq. Same altitude, same gas. 26 psi spike, tapering to 24 psi. |
(Post 7359867)
Dont get too hung up on numbers. I have a simliar tune as you and I hit 320 whp 420 wtq. Same altitude, same gas. 26 psi spike, tapering to 24 psi. |
Probably the only dyno in Alaska? Lol good numbers though.
(Post 7359596)
(Post 7359596)
Those are corrected numbers according to the sheet.
