Dyno Results Dyno pictures, videos and dyno results.
View Poll Results: Guess what my dyno whp will be!
290-300
31.58%
301-310
31.58%
311-320
15.79%
321+
21.05%
Voters: 19. You may not vote on this poll
Place your bets people! What will by my Dyno Numbers?
Old Mar 14, 2011 | 02:19 PM
vahdyx's Avatar
I'm getting my car dyno'd tomorrow morning at a local shop. I'm going back to the first dyno (Superflow) because they're offering it to me for free, I went and complained about the numbers, I didn't think a tune will increase my car 150 ft lbs of torque!!! They agreed and I'm getting it redone on Tuesday.
Dyno #1 With just ZZP Canned Tune I measured 262 whp and 371 wtq via Superflow Dyno 3rd gear pull
Dyno #2 ZZP Canned tune (no retune), Downpipe, exhaust catback, Intake Tube, dejon bypass valve spring (aka surge add-on), and ZZP upper charge pipe I measured 291 whp and 307 wtq via Dynojet 4th gear pull
Dyno #3 will be on the superflow dyno again, what do you think I'll get this time. All the stuff in my sig will apply!
With ZZP's tune, I'd lose a lot of boost pressure at higher rpms, with Trifecta I keep it until redline which is cool.
Thanks
Also keep in mind I live 5700 above sea level and I believe the shop is at 5500 above. Also tomorrows weather is supposed to be...
62 degrees High
50 degrees about the time of the dyno
32% Humidity
Well results are in folks.
Old Mar 14, 2011 | 02:28 PM
bogalusahondakiller's Avatar
does your car still pull like a beast and shread tires until 3rd at half throttle and
Old Mar 14, 2011 | 02:46 PM
vahdyx's Avatar
Well, I spin for sure through 1st and second, but third not so much. I usually get traction from the bottom until top.
Old Mar 14, 2011 | 02:50 PM
mine did that ONE time lol. now its just a little pu##$ car. Why am i aways the test dummy for things to go wrong
Old Mar 14, 2011 | 06:28 PM
vahdyx's Avatar
What went wrong? You mean you had dyno problems?
Old Mar 14, 2011 | 08:26 PM
86buick09sstc's Avatar
IF the dyno issues are fixed at the dyno #1 place im thinkin you will get 307whp and 331tq... pullin that out of my butt but sounds good! IF its not fixed... 274whp and 380tq with a side of clutch slippage perhaps
Old Mar 14, 2011 | 09:16 PM
mine is fixed now. it was my new tune. something went wack
Old Mar 14, 2011 | 09:23 PM
And i had a tune issue not dyno. ill get dynoed soon
Old Mar 14, 2011 | 09:27 PM
MastaShaKe_88's Avatar
when did you that armrest an springs???? Those alone net about +215 ft/lb tq!!!
Id say around 334 hp, 350-345ish ft/lb of tq... on ze trifecta tune of course
I don't know how the weather will effect it... but mods alone, you should be good
will def be 320 or up tho...
Old Mar 15, 2011 | 03:04 PM
vahdyx's Avatar
Results are in 310 whp and 377 wtq
Old Mar 15, 2011 | 03:38 PM
o i meant at the crank tis a lotto torques tho
Old Mar 15, 2011 | 05:04 PM
im good lol. i said 301 to 310..
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
metroplex
Sep 27, 2015 07:48 AM
