LED projector vs Reflector
I installed LEDs into my projectors and they work great.. Now I want to get LEDs for the highbeams..I just now noticed that my highbeams are in the reflector style housing.. Im pretty sure I know the answer to this but wanted confirmation... If I purchase the same LEDs and put them in the reflector housing, that will be brighter and illuminate more than the projector housing, right?
I can’t speak from experience, I would think that you would get a wider spread of the light but not as far down road because the light is less focused. What kind of LED’s did you get? I’ve been considering LED’s for my low beams as well.
I have the spec d ccfl halos/projectors and they have enough room for the fan on the LEDs. Does require u to bend the pin a little that holds it into the assembly. Only because when u twist the led into place it hits that pin, unlatching. You just have to bend it back away from the light a little.
Ended up ordering some hids.
Every projector is different as are led light brands for the most part. It's possible that some manufacturers have the focal point set better than others. They all look pretty much the same based on pics though.
