09 headunit in a 07 car, how?
Old May 16, 2010 | 01:54 PM
Cptn Pants's Avatar
So I ordered an 09 head unit for my 07 car. I have a few stupid questions that I probably should have asked before I ordered it.
1: How do I remove the old head unit? Is there a DYI around here?
2: Will my steering wheel controls still work?
3: Can you play MP3's off a USB thumb drive? If so, whats the size cap? 2gb,8gb16gb etc.
4: Will I have to go down to chevy to have them "unlock" the radio, if so how much will that cost and what do i need to bring for them to do it?
and LAST dumb question: It's a black head unit on a silver dash, how dumb is this gonna look? lol.
Thanks for all the help guys!
Old May 16, 2010 | 01:56 PM
EcoTecDriver's Avatar
that was a dumb move, well type up a forsale ad cause it will not work.
Old May 16, 2010 | 01:58 PM
BlackLT08's Avatar
will it work on an 08 lt?? If so I might take it off his hands.. head unit is the missing piece of my black interior!!
Old May 16, 2010 | 02:19 PM
Cptn Pants's Avatar
I thought it read that all 07s and newer used the same headunits and you only had issues with the older models. If that's bthe case ill just cancel the order, it won't ship till Monday anyways.
Old May 16, 2010 | 02:20 PM
Nighthawk243's Avatar
An 09 HU should work in an 07... same databus. Its the 05-06 that cannot run the newer HU's without a ton of rewiring and a GM tech that knows his way around a Tech II. You'll just need it flashed to work with your car's VIN or else it will just display "LOCKED".
Pretty easy. Just pull off the lower kick panel that sits below the column, pull off the trim immediately to the right of the column, pull off the trim above the glove compartment, and then finally pull off the trim around the stereo/HVAC controls. Once you get that trim off, there should be two 7mm bolts holding the HU in. Disconnect the 2 (or 3 if you have XM) plugs from the back. The reinstall is the inverse of removal. I suggest using new clips on the trim panels or if you're cheap, some gasket tack to prevent squeaking from the clips being looser than before.
They should. The control buttons on 07+ are the same.
From what I've heard, they do not read thumb drives. The USB port was mainly intended for docking an iPod to the radio to allow it to charge and be controlled.
Yes. They will charge about an hour of Labor or the minimum labor charge. They use a Tech II tool to do this, so there isn't a DIY method.
It really depends on your tastes. It may look different, but you can easily obtain the black facing for the HVAC controls to make it match.
See red.
Old May 16, 2010 | 02:54 PM
Cptn Pants's Avatar
Hey thanks, Nighthawk243 that's exactly what I wanted to know.
Old May 20, 2010 | 03:20 PM
Cptn Pants's Avatar
Ok, so I installed it and it works great, it doesn't look terrible but I do plan on getting some black trim and HVAC stuff for it. Chevy charged me for an hours labor which was about $100. Just though I would let you guys know. Thanks again Nighthawk243.
Old May 20, 2010 | 03:47 PM
ChevyRockstar's Avatar
take the "chrome" off your vents,radio looks good wish i could do this
Old May 20, 2010 | 03:52 PM
Dr.Balt407's Avatar
too bad i have a 05 or i would get a black head unit also.
Old May 20, 2010 | 05:41 PM
BlackLT08's Avatar
damn that looks nice... I want that exact radio.. Cant afford one thos so Im lookin into an 07 black one. If you wanna see what the black trim looks like I have pics in my gallery...
I have a black hvac so far just need the stereo
Old May 20, 2010 | 10:40 PM
Cptn Pants's Avatar
The radio itself was cheap, $90 with shipping on ebay... it just got expensive when Chevy charged me to unlock it lol. And the trim looks good, Im gonna pick up a set soon, maybe paint it my interior also. Idk yet, next step rims!
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
no_ss
Sep 18, 2015 11:03 AM
