6.5" vs 6"x9"
6.5" vs 6"x9"
Hello! I'm about to change all my speakers. I want to put component Pioneer Stage 3 in fronts. I have a 2010 Cobalt LT without Pioneer system. Is it easy to fit tweeters in A pillars as with Pioneer system? Also, I don't know what to put in rear deck. Some people say a round speaker is better than an oval one. Why? Also, with proper bracket, would it sound better to get another component set and install this in rear deck? Thank you for your answers!
depends on the tweeter. im sure you can make em work under the factory grill but it probably wont be pretty or perfect by any means. the reason people say round speakers are better then oval is because when comparing apples to apples a round speaker does sound better. the problem is most times people are comparing apples to oranges and even if they aren't the difference isnt always night and day.
Are you going to amp the speakers? if not then i wouldn't go with a component set in the rears (i wouldn't in the fronts either but hey whatever)
Why not components??? My headunit has a 200W built-in amplifier! It's loud enough for me XD And you are talking about comparing apples to apples. The oval speakers I want are Pioneer Stage 3 and round too. Same speakers, just one oval and the other round!
Check out my headunit AVH-P4300DVD - In-Dash 2-DIN DVD Receiver with 7" Widescreen Touch Display and USB Direct Control for iPod®/iPhone® | Pioneer Electronics USA
Built-in amplifier: MOSFET 4x50W
Just stupidly loud for anyone -_-' Volume goes up to 40 and at 20, my ears hurt XD I usually listen at a volume of 12/40!
sure and that's sorta what i was going to explain but i figured it wasn't worth the effort or the rambling. That hu is actually a whooping 14w rms per channel and 50w peak. since peak is basically a bs number that companies make up now a days its probably not a good idea to look at it. so you HU and maxed clipped to **** power will give those speakers just under 1/4th the power they can handle. at that point coax or component wont matter bc anything will sound like garbage. my point i was vaguely trying to make is on paper a comp looks better and everyone and their mom wants one because they think it sounds better. but the reality is a comp set "can" sound better but doesn't necessarily mean it will.
when a 6.5 comp set is installed in the same position as a 6X9 coax would be then the only difference is the materials of the speakers the efficiency and the cone. the materials are similar enough since you are comparing the same line of speaker, the efficiency of the coax is almost double that of the comp set and the larger cone area of the coax gives it a volume advantage as well but the oval can decrease the "sq" somewhat. so when you actually weigh the real world differences the comp set doesn't look as attractive anymore.
Overall when your talking about speakers in the exact same position off of a HU then efficiency is king. When you put real clean power from a quality amp then your comp set will pay off but until then your just giving yourself a sugar pill.
So... if I want a component set, I need a good amplifier? The problem is that I don't want to be deaf at 30 years old XD I do not want an 600w amplifier that I will just put at minimum gain...
your stock amp is 260 watts if i remember right. if you want to put a 400 watt in there. little more wattage that will go hand in hand with your component system if you choose. you wanting good mids highs and lows. a decent sub will handle your bass. a good 400 watt amp will handle the rest. just picking the amp is what you are after, then picking speakers meant for that rms range is key. people tell me that my **** sounds really good in my car and it bangs hard. stock door speakers, pioneers in the back and a JL sub matched with a 1000 watt amp. i get great sound with my **** as it is. but what does a drunk guy know? my .02 cents
my point is mainly that there's nothing wrong with the co-ax design and in alot of cases they fit the bill just fine. now i cant comment on how good the stage 3 stuff is but alot of companies make quality co-ax's that mop the floor with some comp sets not only in sound but also dollar for dollar. if you want a comp set thou thats fine but the advantage they have over co-ax's is normally negated unless you have an amp to power it. and you dont really need much and you dont have to crank it up but component speakers need more power then a hu can provide period. Plus an amp will give you much cleaner power. and you don't even need an "awesome" amp. the amp in hu's are the bottom of the barrel base smallest amp possible.
@cobalt2010: I don't have the Pioneer system... When I bought my car a year ago, I already knew I was going to change headunit for a touchscreen one!
I just want speakers to sound clearer... So you tell me to go with coaxial speakers? Why then Pioneer sound system has tweeters with 270w amplifier and it sounds great? I don't understand why I need an amplifier and stock system do not need a good one... Sorry if my questions are stupid but I'm trying to understand all this before I buy the speakers! Stock amplifier is 270w... 70w goes to subwoofer... and 200w to other speakers... it is peak power not rms... so 200w to other speakers is bottom line amplifier like I have in my headunit, isn't it? My subwoofer has its own amplifier so it is not powered in any way by my headunit.
@cobalt2010: I don't have the Pioneer system... When I bought my car a year ago, I already knew I was going to change headunit for a touchscreen one! I do not either. i described what i had compared to yours. mine is the same **** as yours.
You're right... Just by changing headunit it's night and day... Sound is so much clearer! Highs are so crisp if I compare with stock headunit!!! I have a Bazooka subwoofer with built-in amplifier (I know a lot of people say those subs are ****, but because I don't put volume on max, it sounds really good! Could be a little more direct bass, but it's a ported box so... I should not complain about it XD). If I buy TS-D1720C component speakers for fronts, TS-D1702R for rears and this amplifier: GM-D9500F - Class-FD 4-Channel Bridgeable Amplifier | Pioneer Electronics USA
Would it be ok?
Would it be ok?
Would it be ok?
Would it be ok?
hope that helps
now my drunk ass is goin to bed
