6x8s?
Old Apr 10, 2010 | 12:30 PM
2009CobaltLT's Avatar
6x8s?
Out of curiosity, would 6x8 speakers fit in the rear deck?
http://www.onlinecarstereo.com/CarAu...ce_6820cs.aspx
Just curious if these would fit.
If not, I would like some help finding good 6x9 components to fit in the back. Will be running an amp pushing ~100 rms.
Or would it be more practical to run some coaxial 6x9s?
Old Apr 10, 2010 | 12:37 PM
BPacak's Avatar
Vtec Rep
I would assume that they would fit but the screws might not match up not sure. i would go with 6x9s. my 6x9s felt like not fitting in all the way because how the frame is, so i put the speaker in from the bottom and screwed it in. just a tip if you have that problem
Old Apr 10, 2010 | 04:11 PM
chitala383's Avatar
i would just go with 6x9's. bigger is better
Old Apr 10, 2010 | 07:33 PM
07blackss86's Avatar
They will not fit properly, if you really want to do a component set in the back then I suggest a 6 1/2 set up. You just need to find an adapter capable of turning a 6x9 hole into something to drop 6 1/2s in. Or just fabricate your own.
Old Apr 11, 2010 | 12:17 AM
EmperorJJ1's Avatar
anything will fit anywhere if you try hard enough but no a 6X8 wont easily fit in the 6X9 hole. i would probably just do a coax and call it done. the hertz energy and hi energy 6X9 coax sound pretty badass
CDT makes a 6X9 comp set: CL-69CX
http://www.woofersetc.com/p3078/CL69...ent-System.htm
SSfamilywagon
Mar 27, 2010 03:02 AM
SSfamilywagon
Jan 8, 2010 01:28 PM
SI FTL
Stuff
Nov 25, 2008 01:00 AM
