Adding amp while Factory powering speakers
Old Jun 23, 2012 | 12:31 AM
a2xvinny's Avatar
I have just finished installing my headunit. My speakers have to much bass in the which ruins any music i listen to so ive been thinking on switching my amp and sub. Is it possible to keep the stock amp to only power the speakers and how do i remove bass in my speakers, my old car never had this problem. Also how do i add a new amp to an aftermarket hu while still having the factory amp.
Old Jun 23, 2012 | 03:15 AM
EmperorJJ1's Avatar
turn the bass down on the HU. what HU did u install?
Old Jun 24, 2012 | 11:52 AM
a2xvinny's Avatar
I installed a JVX KW-R800BT and dont worry my bass is at 1 and still kicks i just want to remove my stock sub to put in my old 2 12" with my old amplifier if i have to i want to keep my stock amp only for the speakers
Old Jun 24, 2012 | 01:34 PM
09BlackLT's Avatar
Ya that should work. I put in a new headunit, which I have the bass at 0 and I use the sub out to run my 2 12's. It seems to work good.
Old Jun 24, 2012 | 01:37 PM
EmperorJJ1's Avatar
thats possible. oh also ur HU has a high pass filter. that would remove bass going to any of the stock speakers (stock sub included)
Old Jun 24, 2012 | 01:58 PM
a2xvinny's Avatar
So i should just put the bass at 0 from my HU and add my new amp to the hu and everything should work? I thought when the hu was at 0 the 2 subs wouldnt produce bass
Old Jun 24, 2012 | 02:03 PM
EmperorJJ1's Avatar
if u have the sub function enabled the "bass" will effect both inside speakers and sub but you will also have an individual "sub" that effects only the subs. and 0 isn't off. there should be a negative like 6 or something and even there ull still get some bass out of both. the only "off switch" would be the individual sub control. or high pass filter for the speakers
so ya if u have the bass at 0 you will still get sound from you new aftermarket subs just fine. id strongly recommend professional tuning of the system once u get it in (or total install would be good too)
Old Jun 24, 2012 | 02:33 PM
a2xvinny's Avatar
il try that out and see how it turns out
Old Jun 24, 2012 | 02:52 PM
Drunkship's Avatar
Along the same lines, if I wanted to keep the stock head unit, replace the four speakers, keep the factory amplifier to power them, and replace the subwoofer and power that with a new amplifier what would I need for materials? I plan on replacing the subwoofer with another 10" shallow-mount so I can keep the stock enclosure.
Old Jun 25, 2012 | 12:47 AM
EmperorJJ1's Avatar
power ground remote wire for amp, Line output converter, rcas, silicone to seal factory box. possible modifications may be necessary on the stock box depending on the sub so maybe a dremel or file screws ect
speaker tabs if they arent included with the speakers. thats about it bro thats a pretty basic and easy install with 2 ohm speakers like uve been pming me about
Old Jun 25, 2012 | 04:22 PM
Drunkship's Avatar
Thanks. Never had to use a line out converter before but I'm assuming it shouldn't be too hard to wire up.
Old Jun 26, 2012 | 01:29 AM
EmperorJJ1's Avatar
ud be surprised BUT the factory sub has red and black wires going to it. so take the 4, find which 2 make a pair and done
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Stuff
Oct 1, 2015 05:47 PM
c_m_shooter
Sep 27, 2015 04:40 PM
