Adding extra speakers
Old Mar 5, 2012 | 02:24 PM
08baltls's Avatar
So like the title says I'm gonna add some extra speakers to my system. The stock position of them makes it hard to hear with the windows down while driving on the highway. So I am gonna add two more into the doors.
I'm already planning for a sub and amp in the trunk for bass so I don't want to add midbass speakers in the doors. But my real question is should I go with 6.5" or 6x9" in the doors added to the 6.5" that are already there?
Old Mar 5, 2012 | 02:34 PM
chitala383's Avatar
IMO you're probably better off with 6.5's. I'm sure emp will chime in here. Haha
Old Mar 5, 2012 | 03:31 PM
08baltls's Avatar
Ok I'm also a bit confused. I had planned on adding the two extra door speakers and an amp and one 12" sub in the trunk. I'm gonna use the RCA outs on the head for the amp to power the sub. For the extra door speakers I had figured I could just tap the stock front speaker wires and run the extras off those. But would that be ok? Do I need crossovers and all that?
All I've ever done is added a sub and amp. I'm a bit confused about all of this. Don't mean I can't do it so don't say read up or go to a pro. I just need clarification and a better understanding of this subject.
Old Mar 6, 2012 | 03:38 AM
EmperorJJ1's Avatar
what speakers do you have? it would be easiest to get better speakers and up the install by adding sound dampening and such
otherwise stick with 2 of the same speakers
Old Mar 6, 2012 | 08:26 AM
08baltls's Avatar
I have aftermarket pioneer 6.5s in the doors and 6x9s in the rear.
Old Mar 6, 2012 | 11:45 PM
EmperorJJ1's Avatar
what series? pioneers in general suck pretty bad but if u got there really high end ones and dont care about wasting money then u might be able to achieve it with them
Old Mar 7, 2012 | 06:37 PM
Ccadet02's Avatar
"I don't want to add midbass speakers"
Yes you do. You want tweeters,midrange,midbass,and woofer in you car your subwoofer goes in the trunk. if you hook up a crossover to all the other speakers giving each speaker the corret range frequencies you will have an awsome sounding system with very little distortion unless you peak you amp out. pioneers arnt bad their primeer line and stage 4 are awsome not so much the cheaper stuff. but if u spend just a little money they sound awsome. my hole car is pioneer and not one complaint from me or any one that rides in my car. infact i get a lot of compliments.
Old Mar 7, 2012 | 08:34 PM
08baltls's Avatar
Well my 6x9s were like $140 for the set. I don't know the model of them but they aren't cheap I know that. But I know the system sounds pretty good as is. I just want more sound in the car cause with the windows down on the highway it drowns it out. So...
Old Mar 7, 2012 | 10:43 PM
EmperorJJ1's Avatar
ya but how about the fronts? 6X9s are all fine and dandy but really people overspend on them and get cheap fronts when they should do the opposite
Old Mar 8, 2012 | 01:54 AM
08baltls's Avatar
The fronts were like $85 for the pair.
Look I don't really give a damn about how much has been or will be spent on this. It's honestly irrelevant. I'm not wanting some audiophiles haven inside my car. I just want speakers arranged in a way so that when I partially roll down my window at 70 I don't have to crank my stereo more then half way to hear it. That's why I figured if there were speakers in the door right beside me pretty much I'd be able to hear it better. Not building a show system here so can y'all just help me out with the issue at hand?
Old Mar 8, 2012 | 01:59 AM
EmperorJJ1's Avatar
ok cut a hole in ur door and put another speaker in there. try to use 2 of the same speaker and mount the speaker to the metal... only reason im discouraging is because u want it louder what ur trying to do wont get it but go head give it a shot
Old Mar 8, 2012 | 02:09 AM
08baltls's Avatar
No, I don't want louder. I want sound that isn't getting so easily pushed in a way that it's drowned out. The front speakers are far enough forward to allow them to be drowned out with the wind and when wind is coming in rushing toward the back of the cabin it hinders the sound from the rears from coming forward. So....
Old Mar 8, 2012 | 02:19 AM
EmperorJJ1's Avatar
Old Mar 8, 2012 | 06:55 AM
Ccadet02's Avatar
looks awsome. i would have covered the whole dash with the vinyl to blend in the center speaker a lil more. but looks awsome non the less. mind if i take this idea and use it in my balt some day??
Old Mar 8, 2012 | 07:00 AM
Ccadet02's Avatar
have you thought about running a 4 channel amp to you speakers? i have an amp on my pioneer speakers 6x9 in the rear deck and 6.5 components in the door. the amp pushed out 75watts to each speaker and i can hear the m clearly with the windows down.
Old Mar 8, 2012 | 11:34 AM
08baltls's Avatar
No cause I've never run two amps off one set of RCA outs.
Old Mar 8, 2012 | 12:12 PM
EmperorJJ1's Avatar
sure do what you do. its not incredibly loud there with a 3" speaker and tweeter but it improves the overall stage height and sound in general even on most stereo music. 5.1 surround is ******* amazing in this car
Old Mar 8, 2012 | 04:09 PM
BartSS's Avatar
I dont know if i missed this but why not put a 4 channel in?
Old Mar 8, 2012 | 04:43 PM
FasterIsBetter's Avatar
First time I bought speakers I actually bought rockford punchs for the front and mb quarts as 6x9s for the rear. Good speakers for only having about 120 in the whole set, of course that was about 8 years ago when I had my Lumina.
Old Mar 8, 2012 | 05:23 PM
08baltls's Avatar
Someone has mentioned it but my head unit only has one set of RCA outs. So I would have to buy a new head unit then two amps and subs. I really don't want to buy a new head unit cause I like the one I have.
Old Mar 8, 2012 | 07:30 PM
EmperorJJ1's Avatar
i have to ask with the speakers ur planning to add where is it ur gonna put them? you could try making some pods in the pillar to fit a pair of 3" and tweet type deal
Old Mar 8, 2012 | 07:58 PM
08baltls's Avatar
I'm planning to add them in the doors. Back just about even with the driver and passenger seats.
Old Mar 8, 2012 | 08:02 PM
Try to get speakers that come with a grill then. Otherwise it'll look like crap unless you get a set with a trim ring.
Old Mar 8, 2012 | 08:16 PM
08baltls's Avatar
Oh yeah, I'm definitely getting grills with em. Given their location it would be crazy not to put grills on them.
Old Mar 8, 2012 | 09:34 PM
EmperorJJ1's Avatar
like so?
