after market headunit
Old Feb 21, 2008 | 11:50 AM
19transam81's Avatar
I have the pioneer D3 coming on monday and i plan to install it myself. Is there any thing i should no before i go into this. Do i have to bypass any stock **** or is it just by the monting kit and wiring harness then boom i am done?
Old Feb 21, 2008 | 06:08 PM
Spun's Avatar
What year/model Cobalt is yours?
What stock stereo did it come with?
Old Feb 21, 2008 | 11:23 PM
i have an 06 SS/SC and it came with the pioneer sound system.
1.This is the mounting kit i am getting.
Dash Kit: Metra 95-3302
2.I no how to bypass the video and ground the parking break.
Now i just need a wiring harness that doesnt cost 200$.
Old Feb 22, 2008 | 01:36 AM
EmperorJJ1's Avatar
you will need a switch for that pioneer to bypass the video
oh and when you get the harness you will need to connect the remote wire from the D3 to the stock pink wire (stock amp) and the red to the sunroof or wiper fuse
Last edited by EmperorJJ1; Feb 22, 2008 at 01:36 AM. Reason: Automerged Doublepost
Old Feb 22, 2008 | 02:14 AM
Spun's Avatar
I'm not to sure which harness to get if you don't want to spend alot of money.
It sounds like the Guru knows what the model # of the harness he needs is but maybe forgot to post it
What do say EmperorJJ1, can ya help us out?
Added- I'm 90% sure that if you don't have a 2007, that the $10.00 Walmart harness should work with a little tweakin
Old Feb 22, 2008 | 04:47 PM
By 10$ harness is that the one for a cobalt without the pioneer sound? Or just any random GM wiring harness for an 06 chevy?
I got the unit for 512$ from al and eds out in southern california. I found their site on google. That was the cheepest one i found and it took about an hour of searching.
Yeah if anybody knows, that would be great. I have only put 2 radios in a car in my life. If anybody knows of an easy way that i could do this job even with a general wiring harness i would love the info.
Last edited by 19transam81; Feb 22, 2008 at 04:47 PM. Reason: Automerged Doublepost
Old Feb 22, 2008 | 05:19 PM
06_SS_S/C's Avatar
Metra 70-2103 for the wire harness. You'll lose onstar if you have it though.
I am installing my Avic-D3 tonight.
Old Feb 22, 2008 | 06:53 PM
EmperorJJ1's Avatar
added some part numbers to the FAQ
Old Feb 22, 2008 | 07:40 PM
Forced SS's Avatar
I would also get the swi-ps to keep your steering wheel controles.I put my avic z1 in today with it and it work just like factory.I used a AI(American international) harness for a malibu with no mods to it.
Old Feb 22, 2008 | 07:49 PM
Metra 70-2103 is this harness a direct fir or do i have to mod it in some way? The only thing i have ever installed was a rockfordfosgate in a probe and a kenwood in a honda. All i had to do was wire it up and plug it in. Will i be doin the same with this harness when my stuff gets here on monday? Thanks Forced SS. Do you have the part number on the one for the malibu? Is it justa n 06 malibu?
Old Feb 22, 2008 | 08:15 PM
Forced SS's Avatar
AI only make one 06 malibu harness.But I will check tomarrow when I go back to the shop. The AI web site is saying gm-22 witch is about $100.00.So not worth it.The harness should come with a fuse tap and jumper wire.And check out avic 411.com good info.
Old Feb 22, 2008 | 08:22 PM
BOOSSTED 06's Avatar
find my posts i explain everything in them, you only need the cheap harness. there is no way to retain onstar on the 05-06 years unless you wire in the stock radio and your aftermarket. if you have the pioneer sound you still only need the cheap harness, i have that set up and it works flawlessly.
they also all pertain to the D3. I found the best speed sensor wire too its like 2 feet from the head unit. Ive had mine in my car for 5 months and it is perfection with bluetooth and sirius also.
cheap harness and the mounting kit and your done
Old Feb 26, 2008 | 02:15 AM
K got it all in and there is no sound. The d3 turns on but there is no sound out of the speakers? do i have to do something to the amp? Where is the vss wire that is two feet away?
Old Feb 26, 2008 | 02:24 AM
06_SS_S/C's Avatar
You probably connected the wrong remote turn on lead for the factory amp.
On the wire harness you bought, what wire did you connect to the amp turn-on wire?
If you have AIM, get on and add me "MikeUW Huskies"...a lot easier than talking on here.
Old Feb 26, 2008 | 02:36 AM
EmperorJJ1's Avatar
Hook up the Pink wire off the factory harness to the remote wire off the new deck. i belive it has a white stripe on it as well
Old Feb 27, 2008 | 08:43 PM
yep... the amp turn on was wrong. Now where is that vss wire and what wire do i hook up to it. I did the bypass and it is fricken sweet. the navi is good but with the vss wire i guess it can be better. I just need to no the wire to use off of the wiring harness and what the vss wire is.
How do i hook up an XBOX to this unit? i have an idea of where i would put it but i dont really know what i need to do it.
Last edited by 19transam81; Feb 27, 2008 at 08:43 PM. Reason: Automerged Doublepost
Old Feb 27, 2008 | 09:16 PM
06_SS_S/C's Avatar
On the 2nd harness on the D3 there are a bunch of RCA inputs. Just connect the xbox to that and you will need a power inverter to power the xbox.
Old Feb 27, 2008 | 09:54 PM
what watt converter should i use?
Old Feb 27, 2008 | 09:56 PM
dman090's Avatar
i bought my D3 today on sale at Bestbuy for 600 dollars
Old Feb 27, 2008 | 10:48 PM
yeah its great. I only spent 30$ on the harness and the mounting kit. So the radio, ipod hookup, and install only cost 585$!
i am getting a sub for the trunk. i have a alpine amp its 400 watts rms. i got it at best buy for 150$ as an open box item. I was thinking about runniing 1 alpine type R. What do you guys think about that sub? Or should i go with a different one?
Last edited by 19transam81; Feb 27, 2008 at 10:48 PM. Reason: Automerged Doublepost
Extreme Dimensions
Jun 29, 2016 11:01 AM
Extreme Dimensions
Pontiac G5 Appearance
Jun 28, 2016 12:56 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
JonyyB
Mar 31, 2005 02:25 PM
