amp for a car pc????
Old Dec 2, 2009 | 08:37 PM
2.2blckbalt's Avatar
I'm installing a car pc soon and eliminating any sort of headunit in my car.
I'll obviously have to amplify the audio coming out of the pc if I want to hear it in my car.
I dont need or want a ton of base but I will be adding a 10" sub.
So basically how powerfull an amp would I need to push the sub, 2 6.5" and 2 6x9" speakers. How many watts would be good for this?
Also what other concerns should I be considering other than the amp wattage?
Thanks for any help.
Old Dec 5, 2009 | 06:32 PM
joshcsepegi's Avatar
a 4 ch 100 watt amp would be fine for the highs but remember for volume control you will need to use the carpc.
Old Dec 5, 2009 | 10:29 PM
brickloaf's Avatar
the amp you need depends on the speakers and the sub, a 100rms 4 channel cannot push 4 speakers and a sub
i would say one 4 channel for teh 4 speakers, and a mono amp for the sub...also are you running stock speakers?
Old Dec 6, 2009 | 03:04 PM
warrenb213's Avatar
yep, when installing a carpc, you should be looking at the audio portion the same as if you were hooking up a system using rca outs off the back of a deck.
are you using an aftermarket sound card? I would suggest you do so, as this will give you so much more fidelity as compared to the majority of sound cards.
Old Dec 7, 2009 | 02:02 AM
EmperorJJ1's Avatar
audison srx5, rockford power 1000, kicker ZX700.5, jl HD900/5
are all good 5 channel amps to go with
Old Dec 7, 2009 | 02:09 AM
celicacavy's Avatar
JL 300 watt four channel for the regular speakers and a seperate amp for the sub but need sub info for a better recomendation
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
