Amp Help!!!
Old Aug 16, 2008 | 11:24 AM
schamsy's Avatar
Amp Help!!!
Ok I was installing my rockford punch 40 amp last night and I only hooked up power ground and remote and a red LED right came on. Is anyone familiar with rockford amps? What does the red light mean? I bought it from a friend and he told me it works?
ANy suggestions?
Old Aug 16, 2008 | 11:30 AM
MP Cobalt's Avatar
Some amps use different colors is it lighting up under the power or protection? My old kicker amp had a red power light
Old Aug 16, 2008 | 11:52 AM
creedin's Avatar
well it shouldn't like up watsoever if you just put them in and the battery is unplugged... most likely it is red (protection) so that it recognizes the power, but has no use for it (no signal) so its not doing anything, but thats just my idea
Old Aug 16, 2008 | 12:48 PM
schamsy's Avatar
Nice, does anyone else have any suggestions...
Creed... So if I had my line output converter connected correctly it may work? I was almost certain I had them hooked up correctly.
Old Aug 16, 2008 | 01:05 PM
creedin's Avatar
yes, most likely it would work if you had it all probably set up
Old Aug 16, 2008 | 08:44 PM
Spun's Avatar
I'm pretty sure the protection light for the old RF's is orange, red is power on
Good way to test it is to get a 3.5 mm to rca cable (headphones to rca) and hook your amp up to an mp3 player. If it produces sound your problem is in your LOC, if not the amp is bad
depending on what year it is you might want to add a LP X-over to the amp for better sound
Old Aug 16, 2008 | 08:50 PM
KillerBee's Avatar
Its probably a protection light like everyone said. Have you hooked up the remote wire? Then seen if the amp actually works? It could mean the amp fuse is blown or somethign is wrong with the amp itself.
Old Aug 16, 2008 | 11:04 PM
Spun's Avatar
I have an old Fosgate Power 1100a2, it has a red light on it, there aint nothing wrong with it.
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Turbo6
Aug 27, 2015 08:37 PM
averagewhiteboy
Nov 7, 2005 12:40 AM
