Amp help ASAP
Old Sep 1, 2008 | 09:41 AM
MP Cobalt's Avatar
Amp help ASAP
Yesterday i was driving to my friends house and my sub just shut off. So when i got there i checked everything and the little fuse on the amp blew. So i got another one and it blew again so does anyone know why that fuse only keeps blowing after like 15 minutes?
Old Sep 1, 2008 | 09:57 AM
bummer's Avatar
sounds like you have a pinched wire
Old Sep 1, 2008 | 09:58 AM
Spun's Avatar
Is it the proper size fuse for the amp?
Is it overheating?
What kind of amp is it and what do you have it running?
Off hand I'd say your working the amp to hard, check where your gain settings are at, fuses only blow because more power than what was intended runs through them, better the fuse than your amp
Old Sep 1, 2008 | 10:00 AM
MP Cobalt's Avatar
It's a Sony 1000watt 2 channel amp i had it for like 3 months and it just did this yesterday. It's powering a alpine type-r. I got the same size fuse that was in it. it takes one of the little 30 bus fuses
Old Sep 1, 2008 | 10:27 AM
Spun's Avatar
First off if it was a pinched wire then the fuse that is at the battery would blow as well.
This is my best guess, you might water damage on the amp board, or something came loose inside and is shorting out the amp (fuse).
If you bought it new, then take it back, as long as its not water damage it should be warranty. If you bought it used then find an electronic repair shop and have them take a look at it.
Does it have a burnt plastic or burnt rubber kind of smell to it at all?
If it is warranty and you take it back, they will have to ship it back to Sony to be fixed, so if this is the case expect to be without it for a while
Old Sep 1, 2008 | 10:43 AM
MP Cobalt's Avatar
No i bought the amp off a guy on here like 3 months ago. Nope when i pop the trunk it just has the trunk smell. When i took the fuse out it was like already out just sitting in the slot. I didn't have to pull it out idk i might take it apart today and look at it
Old Sep 1, 2008 | 10:46 AM
joeworkstoohard's Avatar
bad amp. or bad speaker. i've never had one of those blow on me.
you have to remember, you can't force electricity into anything, it has to complete a circuit, so logically, it's unlikely that it's the power wire to the amp from the car, that should blow the fuse on the power line, not at the amp.
most modern amps wont let you draw enough power from them to damage them, so it's most likely a bad amp. IMO
Old Sep 1, 2008 | 11:09 AM
MP Cobalt's Avatar
idk it just did it yesterday. I had it for 3 months and all of a sudden it blew the fuse yesterday
Old Sep 1, 2008 | 11:12 AM
coulda been a fluke, let it cool down, and try again.
the other thing is, if you can, open the amp up and lok for some burnt up shizz
Old Sep 1, 2008 | 01:05 PM
bummer's Avatar
the reason i said pinched wire was i had a amp in my truck for a year and the remote power wire routed under the trim over time rubbed the insulation down to the wire and it touched the clip holding the trim and kept blowing the fuse.
Old Sep 1, 2008 | 03:32 PM
the remote wire? odd.
Old Sep 1, 2008 | 06:57 PM
MP Cobalt's Avatar
Idk i just dont want to pull the headunit out again and see if it might be something back there. I hope its just the amp cuz i plan on getting a new one. Just not this soon now
Old Sep 2, 2008 | 01:32 AM
EmperorJJ1's Avatar
lol amp has an internal problem.... watch out when u open that board... if u mess it up then hook it up to your sub it can go boom. then again sonys dont have any parts but a **** load of white lithium grease
Old Sep 2, 2008 | 02:04 PM
Spun's Avatar
My best very un-educated guess would be that you blew a resistor, thus alowing to much power to flow and blowing the fuse, although usually when you blow a resistior thewhole unit does not work. IDK like I said its an un- educated guess. You should have a repair shop look at it, but for the price might be worth it to look into getting another amp, ebay is your friend.
Lithium grease (lol) gotta love sony's
Old Sep 2, 2008 | 03:11 PM
EmperorJJ1's Avatar
i know huh. Have you seen inside a sony board? God damn. Honestly even opening it up your not going to figure it out. Without proper testing equipment and the knowledge on how to use it your not going anywhere.
Best thing to do is check everything in your install and rule the amp as the problem. May not get you far but who knows
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Cobe
Sep 19, 2015 11:04 AM
Turbo6
Aug 27, 2015 08:37 PM
