amp help!!!plzzz
amp help!!!plzzz
i want two 12' kicker cvr's they can handle 1600 watts
will someone find me a amp that will run 1600watts at two ohms.
it seems like i cant =[
thanks
bumpppp
thanks guy haha
thanks
bumpppp
thanks guy haha
Last edited by braddddddd991; Oct 30, 2007 at 10:35 PM. Reason: Automerged Doublepost
Im sorry if this makes you mad in anyway at all .. but their is only one way to say this. If you think you can just throw the max wattage at a speaker constantly, you my friend are stupid. That max rating is there to show you the max input wattage the speaker can handle for a maximum of 25-30 seconds. Always go by your RMS wattage maybe 50-75 watts more depending on what your cone and voice coil are made out of. But to each their own. If you want an amp try www.onlinecarstereo.com Good luck blowing those bad boys up.
max wattage ratings are useless... dont use them period. I bet i can put my amp on them for 30 secs and blow them (rated 3.5ish kw at 14v @1ohm so half of that is a lil more then 1600) bring it on
