Apparently im retarded, amp clipping need help!
Old May 5, 2010 | 02:40 AM
mikelpn's Avatar
Yeah upgrading to the 4 gauge with an 80amp fuse has cured all of my issues I'm excited. This is the first all of my components have worked in forever. I'm hoping I finally got all the kinks worked out and I wont have any more issues.
Old May 9, 2010 | 07:10 PM
lilhomieb07's Avatar
Dude sounds like exact problem i just had. IF u are running the stock AAS system. My vol should go almost to max but im goin to 20-35. I found out my amp clipped at high vols because my aftermarket alpine H/U was causing the stock amp to overheat and then it somehow triggered my sub amp to clip.
But deff use 4gauge wires for power and ground, i have a 150a fuse on my power wire. Im having my amp bypassed tuesday so i should be good to go then.
Old May 9, 2010 | 11:59 PM
Spun's Avatar
Good, I'm glad it worked out for you.
The Rookie24
Jan 20, 2016 05:14 PM
HEATON
Oct 16, 2015 07:21 PM
yellow dragon
Sep 28, 2015 09:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
