attaching amp to factory battery
Old Mar 19, 2009 | 11:51 AM
polarbair's Avatar
Tried a search but couldn't find an answer to a simple question. How to attach an amp to a factory battery setup. have an 08 base ls.
Old Mar 19, 2009 | 11:52 AM
originaladrian's Avatar
same way you do any car. nothing special about a cobalt.
Old Mar 19, 2009 | 11:53 AM
KyleMinnis's Avatar
you gotta buy a power cord and a ground cable at least...
and cobalts are way easy cause our battery is in our trunks
Old Mar 19, 2009 | 06:18 PM
d4rlp3nc1l's Avatar
yep our trunks are soo big, we can fit a bike and a battery in it. lol. but, yeah, what would make you think it would need to be wired up differently.
Old Mar 19, 2009 | 10:16 PM
not necessarily lol...
doing my power cord upgrades was a bitch.
Old Mar 19, 2009 | 10:26 PM
brickloaf's Avatar
power wire goes from positive post to plug in amp
ground wire goes from amp to basically anywhere metal
Old Mar 19, 2009 | 10:49 PM
stinkyfisherman's Avatar
Put the ground also strait back to the battery. Its a better ground
Old Mar 19, 2009 | 10:50 PM
not the neg on the bat....
never
body ground.
always.
Old Mar 19, 2009 | 10:53 PM
Killa SS's Avatar
never
body ground.
always.
y is this?
Old Mar 19, 2009 | 11:01 PM
EmperorJJ1's Avatar
news to me
Old Mar 19, 2009 | 11:06 PM
Killa SS's Avatar
thats wut im saying. ive always ran my ground to my batt in my balt for the amp and ive had three diff systems in it.
Old Mar 19, 2009 | 11:32 PM
brickloaf's Avatar
my amp is to far away from my battery to ground it there
Old Mar 19, 2009 | 11:39 PM
EmperorJJ1's Avatar
what do you consider too far?
Old Mar 20, 2009 | 12:26 AM
brickloaf's Avatar
it was on my back seat
Old Mar 20, 2009 | 12:37 AM
EmperorJJ1's Avatar
id still run wire to the battery. as long as its real copper good wire it will be better then grounding to the metal
Old Mar 20, 2009 | 12:38 AM
brickloaf's Avatar
well ****, i literally just ordered all new wiring (3-4 hours ago) and i only got 2 ft ground
Old Mar 20, 2009 | 12:51 AM
EmperorJJ1's Avatar
well you can wire it to the metal too if ud like. what brand of wires did you go with
Old Mar 20, 2009 | 12:54 AM
brickloaf's Avatar
0 gauge from knukonceptz, it was the kollosus or however you spell it
i spent like 90 bucks on everything, i got 6 ft of power, 2 ft ground, triple battery terminal thingy, high flow inline fuse, 10g kasa speaker wire and a 0g terminal ring for grounding
Old Mar 20, 2009 | 12:56 AM
EmperorJJ1's Avatar
nice... thats the good **** you need for the fosgate
Old Mar 20, 2009 | 01:04 AM
brickloaf's Avatar
lets just hope someone can fix it first
Old Mar 20, 2009 | 08:17 AM
Originally Posted by Killa SS
y is this?
i used to know the answer i swear lol.
something about using a common body ground to ensure no stray voltage or something like that, ill find it.
ither way. what do you think your battery is grounded to? your taking a longer route. the voltage does not go like... back into the battery.
now all your grounds just use the neg terminal of your bat as a point to collect your stray voltage and pass it to your body ground.
ill find the actual answer somewhere tho hold on.
Old Mar 20, 2009 | 09:41 AM
EmperorJJ1's Avatar
Just some food for thought,
whats the difference from ac voltage in a house and dc voltage in a car other then the obvious alternating part? they are both electrical circuits with a positive and a negative in AC the "ground" is a completely separate conductor and all its purpose is to be a protection device, in the case of over current for some reason electricity should flow along this ground and hopefully prevent ur house wires from melting and causing a fire.
In a dcv car the "ground" is nothing of the sort it is the negative circuit hence removing the battery ground and ur car electrical components no longer work. Assuming you had a very basic vehicle electrically and the battery was up front like normal... play along with me and we'll assume the alt wasn't connected to the engine electrically with metal and the engine not connected to the body and each electrical component that normally gets its negative via that connection had its own wire running straight to the battery... If you were to eliminate the body ground and use wire to connect the battery and alternator would the car still work? (remember very basic old vehicle, no computer ect)
The answer is yes all dc needs is a pos and neg and as long as they are safely connected electrically it would work exactly the same but it seems a lil redundant to do all that work to make sure the negative isn't touching the body and making a body "ground" as we know it today. Along with the fact that in cars today there's so many different electrical components that "ground" to the closest place they can find. One could argue the only reason for a body ground is to save money. Why pay for tons of copper wire when your surrounded by metal? The second reason for the body ground is like you stated resistance. the fog lights or whatever in the engine bay that's grounded there will have a better connection resistance wise then running a thin wire all the way to the battery in the back. The only way for it to be a better connection resistance wise were if you connected them with a wire thick enough to have a lower resistance then the body ground. Running 8g or whatever for EVERY electrical component to ground straight to the battery is not only obnoxious and boarderline impossible but again expensive.
Copper is a better conductor and has lower resistance then steel. so if the battery is close its will have less resistance to ground to the battery directly
Old Mar 20, 2009 | 10:09 AM
polarbair's Avatar
I'm sorry. apparently in typical fashion, I didnt clarify my question. My bad. Yes, Positive to positive and negative to negative, that part I got. My question is in looking at the factory battery they installed, it doesnt have secondary posts. Do I have to replace the factory connector thats on the posts? how do I make the connection TO the battery?
Old Mar 20, 2009 | 02:23 PM
xray_racer's Avatar
I am no expert, but I have had some experience and I know when I put a new engine in my '70 Camaro and didn't connect a wire from the battery to the frame of the car the starter would not turn over. As soon as I connected a wire from the neg bat terminal to the body it started right up. Someone that understands this better please speak up, I would like to know. Thanks
Old Mar 20, 2009 | 03:29 PM
Spun's Avatar
Make sure you have a nice warm place to work with 0 guage
It tends to get a bit stiff when its cold.
It was cold as hell when I did my 0 guage from the battery to the fuse box, had to use a hair dryer to warm it up in order to bend it in some places
Sorry didn't flip to the second page, the post was directed at brickloaf
