audio guru's I NEED HELP
Old Sep 16, 2010 | 11:07 PM
G_Pelly's Avatar
ok so i got a 06 cobalt ss s/c
so i have a cavalier z24 and i decided to take the amp and sub out today and put it in the cobalt
i followed this how to https://www.cobaltss.net/forums/how-...eadunit-85131/
i followed it step by step and i turned it on and it seemed like it was working but im pretty sure its just the stock sub hitting or just barely on barely on, my bass boost and all the controls on the amp wont work it use to vibrate my brain but now it seems like it isnt working
any body have any ideas to whats wrong, the amp and my capacitor are on and seem to be working, and the remote wire on the amp works i dont know what is wrong help!!
Old Sep 16, 2010 | 11:08 PM
G_Pelly's Avatar
oh and my amp is a 1600w hifonics brutus and my sub is a pioneer premier 3000w max
Old Sep 17, 2010 | 12:16 AM
JshLnsctt's Avatar
I would start by taking a voltmeter to your power line coming in as well as your REM wire. I would also check the resistance on your ground wire to make sure you have a good ground.
Old Sep 17, 2010 | 01:45 AM
scottie's Avatar
do you have it wired up to a aftermarket headunit or using a output converter?
With that much wattage out of an amp, it either works or it doesn't. lol
Old Sep 17, 2010 | 02:04 AM
G_Pelly's Avatar
The stock stereo with the converter and my amp is 1600w
Old Sep 17, 2010 | 03:10 AM
EmperorJJ1's Avatar
try this... if u have a pair of rcas plugged in unplug one of them
Old Sep 17, 2010 | 03:53 AM
warrenb213's Avatar
correctamundo i bet. balanced outputs from the converter. i have the same thing with my carpc.
Old Sep 17, 2010 | 11:13 AM
G_Pelly's Avatar
I thought I tried that but ill try again
Old Sep 17, 2010 | 12:45 PM
G_Pelly's Avatar
Well I tried only plunging one rca in but it didn't work
Old Sep 17, 2010 | 09:05 PM
warrenb213's Avatar
ok honky.
lets run diagnostics.
does your amp get power?
which wires did you splice into with your LOC?
is your LOC adjustable?
those three questions will help figure out which direction to go with further diagnostic.
Old Sep 17, 2010 | 10:10 PM
G_Pelly's Avatar
Yes my amp has 14 volts going through it when the car is on and I hooked up the converter to the rear speaker wires how do I check if power is going to the sub will there also be 14 volts in the speaker wire going to the sub?
Old Sep 17, 2010 | 10:11 PM
G_Pelly's Avatar
And yes the loc is adjustable
Old Sep 17, 2010 | 10:44 PM
EmperorJJ1's Avatar
you have 14v on both power and remote? and ur testing with the ground on the amp?
Old Sep 17, 2010 | 11:21 PM
G_Pelly's Avatar
I haven't checked the remote but I assume its ok since the amp turns off.when I turn the car off, and yes the ground for the amp,
Ok Im pretty sure I found out whats wrong I get power from the sliced wires up by the rear speakers but not down where the wires are sliced for the converter so I guess that wiring is no good ill try reading it tomorrow and see what happens but I got another problem,
My capacitor got disconnected with the grand disconnected and the capacitor lost all its juice, can anybody tell me how to recharge my capacitor I forget
Old Sep 17, 2010 | 11:26 PM
mbowen89's Avatar
A capacitor charges up to the voltage it is in parallel with. It will recharge by itself the next time you have it hooked up properly.
So you have the LOC spliced into the rear speakers. RCA from the LOC to the AMP. 14V and GRND to the amp, and 14V to the remote.
If that is how you are having this setup, that should work no problem. Make sure you have the correct buttons and knobs all set correctly the amp as well.
Old Sep 18, 2010 | 12:07 AM
G_Pelly's Avatar
Well i hooked it back up and it didn't even light up
Old Sep 18, 2010 | 03:24 AM
EmperorJJ1's Avatar
if its digital it should light back up when u turn the car on/off (not necessarily the first time might have to turn on then off to see it)
Old Sep 18, 2010 | 05:24 PM
warrenb213's Avatar
ditch the capacitor.
it's a band aide anyway.
so it appears the outputs on the amp are actually outputting, just not making it to the end of your output wires? that sounds like a broken pair of wires to me.
also, from reading i almost got the impression that you have the 7 speaker system? the one which came with a stock sub? if so, your not going to want to splice the rear speakers but instead the stock subwoofer wires.
Old Sep 18, 2010 | 07:26 PM
G_Pelly's Avatar
Well thanks guys I got it fixed it, it was a bad connection by the converter but thanks for all your guys help
Turbo6
Sep 24, 2015 04:15 PM
SS SCHGD
Feb 24, 2006 02:21 PM
mugencivicsi
Canada
Feb 23, 2006 12:32 AM
NGASales
Aug 18, 2005 05:45 PM
zinner
Jun 5, 2005 06:35 PM
