Aux jack on a '05?
Aux jack on a '05?
Ok, I have a 05 ss/sc and want a aux jack like the '07s.
I know very little about this kinda stuff, But from what i have read it seems you cant swap radios.
So what is the easiest/cheapest way to do this?
You don't have to if you don't want you can keep the stock radio go to an audio shop and ask how much it will cost I think it should be around 50 to 80 dollars I asked cause im going to do it lol
nope there is no aux input of any kind on most stock radios other then the jacks in the front. For those that dont have said jack the module acts like your sat radio tuner box and gives you the aux that way. So its expensive because its really not "simple"
Damn it... lol Well thanks for your help man
it is almost impossible but not because of the DIC. because all new gm radios are programed with theft protection software that memorizes the VIN along with a bit of communication with the car itself via gm lan. basically the old and new stereos use different codes to do this so even splicing the wires and all that doesn't work
https://www.cobaltss.net/forums/electronics-audio-video-49/audiovox-fm-modulator-question-17720/
I did this when I first got the car. Still works great to this day
EDIT: Ignore this link, I'm looking for the right one.
EDIT 2: Here is the link!
https://www.cobaltss.net/forums/show...ovox+modulator
05
Radio Constant 12V+: red/white
Radio Switched 12V+: GMLAN Serial Data
Radio Ground: black/white
Radio Illumination: n/a
Radio Dimmer: n/a
Radio Antenna Trigger: yellow
Factory Amplifier Turn On: pink
Left Front (+): tan
Left Front (-): gray
Right Front (+): light green
Right Front (-): dark green
Left Rear (+): brown
Left Rear (-): yellow
Right Rear (+): dark blue
Right Rear (-): light blue
2007 Chevrolet Cobalt Supercharged with Pioneer Audio Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power. The accessory turn-on and amplifier turn-on are controlled by the class 2 serial network.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Factory amplifier is located behind the driver side of the dash (near the firewall).
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Dark Green
Right Front Speaker Positive Wire (+): Light Green/White
Right Front Speaker Negative Wire (-): Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/White
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Tan
lol thats ok
Radio Dimmer: n/a
Left Front (+): tan
lol thats ok
wire colors should be the same even for pioneer systems. interesting. gm is normally the best at keeping amp wires the same but speaker wires are always the grn/lt grn, blue lt blue, tan/gry and yel/brn
https://www.cobaltss.net/forums/showthread.php?t=17720
