AVIC-D3 Install Questions
Old Sep 1, 2007 | 05:39 PM
BOOSSTED 06's Avatar
I have searched and can't seem to find the answers I'm looking for.
Im getting the AVIC D3 and here are the questions.
I have a 06 SS/SC with Onstar and I want to keep it intact because i use the phone through my verizon service. Has anyone confirmed that the GMOS-LAN-04 harness works on the 06 to keep the factory onstar and pioneer speakers and sub intact.
If it works is there any special wiring needed.
Also what wire am i splicing into on the car to get the VSS signal for the navigation?
Lastly has anyone use the pac harness to keep the steering wheel controls intact and does it work.
Answers asap would be great, thanks
Old Sep 1, 2007 | 05:46 PM
kingg5's Avatar
i just had the aviz z2 installed....seriously man if u dont have the knowledge or the xperiance...have it done proffesionaly
WSFrazier's Avatar
I always wonder why people go for the D3 and not the Z2. Z2 is a lot better, but I don't think I've seen one installed yet on a Cobalt, but quite a few D3's.
NVM, he's got one ^^^
Old Sep 1, 2007 | 05:49 PM
kingg5's Avatar
i have one yes but i didnt install it in my G5 i put it in my blazer as that is what i drive daily...i never drive my G5 ....its a weekend car. ill post pics right away just gotta go take them. and im pretty sure most people get the D3 as it is 1000 dollars cheaper then the Z2
Old Sep 1, 2007 | 05:52 PM
I have done stereos before ijust need my questions answered
Old Sep 1, 2007 | 06:16 PM
kingg5's Avatar
yah but there arent many stereos that require taping into speed sensor wires n **** like that ...these avic's have like 7 or more different plugs that go into the back....seriously man...get a proffesional to wire this thing if u want every feature to work properly...and if u dont want to **** up your car.
here it is
my subs..
it took alot of cutting to fit a double din into a 1.5 din hole hahaha
Old Sep 1, 2007 | 06:19 PM
ok I still havent gotten an answer to any of my questions.
I can handle the install, i just want to make sure i get the right parts
Old Sep 1, 2007 | 06:41 PM
kingg5's Avatar
ok then in that case...buy the unit then u will be able to determine what u need to buy. there is alot of plugs right...so u may need some stuff..
Old Sep 1, 2007 | 06:43 PM
I Need To Know If The Harness Works. Are You Reading The Questions At All?
Old Sep 1, 2007 | 06:47 PM
kingg5's Avatar
if udont know that then why wouldnt u take th ecar to a proffesional..
Old Sep 1, 2007 | 06:48 PM
Stop jacking the post, i have called them and they dont know, thats why im trying to ask on here. Isnt that what these forums were created for
then he said the GMOS-LAN-04 would work, but im still skeptical because it says 07+ cobalt and i know the wiring is diff on the 06 and 07 balts, thats why im asking.
Old Sep 1, 2007 | 06:53 PM
kingg5's Avatar
ok my bad makes sense i guess....
Old Sep 1, 2007 | 07:12 PM
bump, i know someone has tried this
Old Sep 1, 2007 | 07:13 PM
kingg5's Avatar
so why a d3?
Old Sep 1, 2007 | 07:15 PM
the best one in that price range, i like the nav interface and such aswell
Old Sep 1, 2007 | 07:16 PM
kingg5's Avatar
ive never played with a d3 how much different fro,m the z2 is it?
Old Sep 1, 2007 | 09:57 PM
not sure
come on guys one person must know, or atleast must know what i need to keep the onstar and stock pioneer system with an aftermarket unit
Last edited by BOOSSTED 06; Sep 1, 2007 at 09:57 PM. Reason: Automerged Doublepost
Old Sep 2, 2007 | 09:57 AM
there has to be one person that installed a new unit and retained factory sub and onstar, im hopeing they will tell me they uised this harness
bump again
Last edited by BOOSSTED 06; Sep 2, 2007 at 09:57 AM. Reason: Automerged Doublepost
Old Sep 2, 2007 | 10:06 AM
andresfurueta's Avatar
yes it does work, i just got mine installed yesterday get a professional, the gms-lan-04 is the correct harness same one for the hhr, onstar will work, and you need to cut the plastic by the firewall to get that radio in........hopefully this helps, o yea cructchfield sells an adapter so you can keep your steering controls, its like 54.00 and its made especially for pioneer radios
Old Sep 2, 2007 | 10:17 AM
ok but basically the gmos-lan-04 worked without switching pins in the harness. That was my worry. All i have to do now is figure out where to tap into the vss wire and the install shouldnt be bad at all
also what plastic by the firewall are you talking about.
people have it installed and havent said that before
ok also do you have an 06 or an 07, i need to know if it works on the 06 we know it works for the 07
called metra so everyone know.
gmos-lan-04 does not work on the 06.
it is very complicated to keep onstar working on the 06 cobalts.
hge said if you dont car about onstar use the XSVI-2103 and just hook up the amp on wire to your new head unit and your good to go
Last edited by BOOSSTED 06; Sep 2, 2007 at 10:17 AM. Reason: Automerged Doublepost
2006ArrivalBlueSS's Avatar
Try this resource: www.avic411.com
Old Sep 2, 2007 | 10:23 AM
no detailed help for the cobalt on that site, the stero is independant i just want to retain my factory pioneer and onstar, if not just the factory pioneer if possible.
Im still skeptikal because the instructions for the xsvi say it cant retain the factory amp
Old Sep 2, 2007 | 10:32 AM
yea i have an 07, gms-lan-04 does work on the 06 from what i understand, no you do not have to mess with the pins, the harness just plugs in, try using an HHR harness best advice i can give you......
yo will retain premium sound with the harness you just need to tap into the speaker wires from your stock harness........i just put aftermarket amps in there, made it very easy, your going to change those speakers sooner or later save yourself the trouble and do it now......
Last edited by andresfurueta; Sep 2, 2007 at 10:32 AM. Reason: Automerged Doublepost
Old Sep 3, 2007 | 11:49 AM
i still dont think it will work in the 06, because pin outs are diff on the 06 and 07.
i need someone who has put it in an 06 the speak up and say yes it works fine without modification
also the hhr radio is the same as the 07 cobalt radio not the 06
Old Sep 3, 2007 | 02:19 PM
where aer you from........west new york?.....im stuck............do not know what to tell you.....i know its frustrating.....the plastic thing that i cut was due to how big the aftermarket harness is........it comes with two boxes that are pretty big.........the radio wasnt aligining with the screw holes so i had to modify it.............
