Back Up lights
Old Aug 23, 2010 | 04:20 PM
Hot Rod Cop's Avatar
Back Up lights
I'm having a problem with my back up lights. Both lights are out. I replaced the bulbs and still no lights. I checked the back up light fuse under the hood and it was fine. I also checked the Trunk accessory fuse and it also was good. My LED license plate light is out also. Do you guys have any other ideas as to what the problem could be? All the other lights on the car work perfectly.
Thanks for the helps guys and gals.
Old Aug 23, 2010 | 04:31 PM
Pyros777's Avatar
If the fuses are good and the lights are good, then you'll have to trace the harness from the lights to wherever the problem is. It could be a short due to a frayed wire or a loose connector somewhere.
Old Aug 23, 2010 | 04:39 PM
danieluf's Avatar
That same thing happened to me. It ended up being the reverse light switch which is located under the fuse box somewhere if i am not mistaken. This seems to be a common problem with our cars. I took my car to the dealership and they replaced it and now everything is fine again.
Just search under reverse light switch and I'm sure you can find some more information that will help you out.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
