best battery
Old Mar 21, 2012 | 12:31 AM
tomj77's Avatar
best battery
people seem to like the optima batterys, wanna put one in my ss/tc, question is, whats the diff between blue,red,and yellow top? what one is best? (i run my batt dead sometimes by leaving stuff on) about how much do they cost? and most important, how do u guys make em fit in the car? they are a little to tall for where the batt sits
Old Mar 21, 2012 | 12:40 AM
YelloEye's Avatar
They fit fine, I had a red and yellow top in my LT. Had a red top for a little bit to try and get rid of my dimming problem. Swapped it out for a yellow top, minimized the dimming issue I was having with my subwoofers.
Red top are pretty much normal batteries but with the AGM technology.
Yellow top are deep cycle and can be run lower without damaging them.
Blue are marine and I don't know much about them.
Try reading up on their website about them. www.optimabatteries.com
Old Mar 21, 2012 | 12:51 AM
tomj77's Avatar
well i get the impression from everything iv read, the yellow top is what i want. so it doesnt push up the spare tire/battery floor cover at all? now i need to find one around here
Old Mar 21, 2012 | 01:12 AM
YelloEye's Avatar
Nope, I had no problem fitting it under the floor. O'Reilly's carries them normally.
Old Mar 21, 2012 | 01:30 AM
Dontstoprunning's Avatar
Blue Marine battery in mine
Old Mar 21, 2012 | 01:32 AM
the blue top is taller and works fine, i had it in my car for about 2 mins and traded a friend for her yellow top
The blue is for like boats so it can sit for long periods of time and start right up like u just drove that day
Old Mar 21, 2012 | 01:41 AM
06_ion2's Avatar
battery is a battery, unless you have a stereo system with an amp get the basic battery.
Old Mar 21, 2012 | 02:14 AM
EmperorJJ1's Avatar
red top has the best cca and warranty. yellow top has deep cycle so best if ur running heavy electronics. blue top is really only good for marine use. like it works for cars but i wouldnt really recommend it
Old Mar 21, 2012 | 07:13 AM
tomj77's Avatar
So if ur running hides buy a yellow top? Cause a normal batt lasts about 5 minutes when the car is off with my hidden on, fogs and driving beams
Yellow top it is for me
Old Mar 21, 2012 | 09:05 AM
tomj77's Avatar
Yelloeye I'm in Canada don't think we have that here
Old Mar 21, 2012 | 10:37 AM
08baltls's Avatar
Jesus Christ! $294 for a battery is ridiculous! That damn thing better last forever at that price.
Old Mar 21, 2012 | 01:25 PM
EmperorJJ1's Avatar
what do you mean a normal battery? if ur battery is fucked now then you cant do much of a comparison of what it can and cant do. also keeping ur hids on with the car off isnt something id recommend but if ur going to be doing it then yes yellow top
Old Mar 22, 2012 | 10:14 PM
09BlackLT's Avatar
Ya we got yellow top's here, I got one in my balt!
Old Mar 24, 2012 | 08:24 PM
tomj77's Avatar
well when i retune my car the lights cant be shut off and i have to put a charger on the car or the batt runs dead. and my batt is finished. iv run it dead so often by accidently leaving stuff on. seriously i leave radio on for 10 minutes and it wont start. dealer says its fine, bs. but ya im gonna order one from driver fx since nowhere else i went to look seems to have em, fricken walmart has read tops but can get yellow tops, which i think is bs, cause if u can get one type from a supplier u should be able to get any type of that brand name.
so what one do i get the d34/78 or the d34
the 34/78 has side termanals more reserve, is smaller a little. pretty much thats the diff
Old Mar 24, 2012 | 09:46 PM
EmperorJJ1's Avatar
right well im saying yes get a yellow top but u cant compare it to ur battery bc ur battery is trash. even a stock replacement will last longer then that... but u need to fix ur lights issue bc if ur lights are basically on 24/7 then doesn't matter what battery u have it will die and die quickly
Old Mar 24, 2012 | 09:58 PM
tomj77's Avatar
they arnt on 24/7. lol stock battery is ****. thats what i have. but the reason it is so bad is because i ran it dead so many times.
Old Mar 25, 2012 | 01:23 AM
EmperorJJ1's Avatar
right thats what im saying ur battery is dead so even a stock replacement is going to take longer to drain and work better. a yellow top will do better then that. just need to watch the hid staying on and baby the yellow top to make sure it lasts for u
Old Mar 25, 2012 | 11:12 AM
tomj77's Avatar
ya, i want it cause it wont kill the battery if i drain it as well. but im having a really hard time finding one.
Old Mar 26, 2012 | 11:05 AM
tomj77's Avatar
Well after tons of searching, Walmart, Costco, napa, Canadian tire in Winnipeg, I asked a girl I know at Canadian tire steinbach who isn't lazy and actually looked into it, u can get optima battery's there, have to order them out of the performance catalog they have. Sweet deal, getting my yellow top ordered today
Old Apr 3, 2012 | 11:10 PM
tomj77's Avatar
well installed yellow top, trunk floor is a little lifted up due to positive wire sitting high. negative hookup is busted so i cant get it totally secure, gonna get a new end tomorrow, cause im sure it will pop off with driving over some bumps
Old Apr 3, 2012 | 11:14 PM
Black SS/SC 06's Avatar
I ran a red top for years with no issues.
Old Apr 4, 2012 | 02:36 AM
EmperorJJ1's Avatar
ive also herd u can turn it on its side to prevent the floor from being lifted
Old Apr 4, 2012 | 01:26 PM
tomj77's Avatar
It has side posts I could just get the stuff to use thOse
Old Apr 4, 2012 | 01:47 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i highly recommend not driving it. loose terminals cause a lot of heat and can melt the terminal right off of the battery.
also there seems to be a little bit of confusion regarding the colors:
red top = starting only. 3 year free replacement warranty.
yellow top = dual purpose deep cycle. 2 year free replacement warranty.
blue top(marine): there are two different versions. one starting, one dual purpose deep cycle. The starting is the exact same construction as the red's, just with different terminal configurations and a 2 year warranty instead of the 3. The dual purpose deep cycle is the exact same construction as the yellow's with the same warranty. They just have different terminal configurations as well.
Old Apr 4, 2012 | 01:55 PM
1AJeremyD's Avatar
I used a yellow top in my Explorer for 2 years with my 2 JL6s pounding away. I've seen bad reviews on them in the past but so far nothing lately.
