Bolt in the trunk blocking box space
Old May 6, 2008 | 01:41 PM
Out1aw's Avatar
Been around for quite a while on here and finally blew my two Type-E 10's that were in my Cobalt. I had way too much amp and way too small of a box so it was bound to happen sooner than later. Just picked up 2 Alpine Type-R 12's, and was specing the box when I noticed a little bolt hanging from the metal brace that goes across the inside of the trunk. Looks to hang down almost a full inch, and is really blocking my way to put in a good box. Does anyone know what this bolt is for, and has anyone ever ground it down at all? Thanks.
- D
Old May 6, 2008 | 02:29 PM
jacobmprater's Avatar
should be ok if u grind it down. or take it out and weld it shut... thats a lot of work thouhg.
Old May 6, 2008 | 02:31 PM
Bumpin Balt's Avatar
It's for the child safety seat anchor. I cut the excess off. It is way longer than it needs to be. I just used a hacksaw and cut it in place.
DoubleLP's Avatar
I would guess that it is one of bolts for the baby seat anchors that are in our cars. But I am just guessing without actually looking at it.
Old May 6, 2008 | 02:51 PM
Spun's Avatar
The big ones actual not for the baby seats I beleive its the tie down for the middle seatbelt. You can try and shorten it but you'll need a grinder. I think the reason its so big it due to safety standards though, by law I think it has to be a certain size/grade, so if you grind it down you might run into problems.
Old May 6, 2008 | 11:14 PM
EmperorJJ1's Avatar
i cut it quite a bit to fit my box. meh theres enough left to be fine.
Old May 7, 2008 | 01:44 AM
Spun's Avatar
I was refering more to the guy who said "grind it down, take it out, weld it shut"
I don't know how it works in the US, but in the Great Frozen North, its part of a vehicle inspection, not that there's any reason why a new car needs an inspection.
Grind it down, as long as it holds then there shouldn't be a problem. Might want to replace it before you sell it.
How often do you have 5 people in the car anyway?
Just take it out, seatbelts and all, turn it into a 4 seater, problem solved.
Old May 8, 2008 | 03:43 AM
EmperorJJ1's Avatar
lol i don't even have backseats right now anyway... but inspection wise its different per state and I'm not 100% sure if thats even going to be looked at (in NM theres no such inspection or anything similar). Personally thou i dont see an issue with cutting the bolt as long as you dont cut it too short.
06MetallicBalt
Jul 20, 2025 08:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
c_m_shooter
Sep 27, 2015 04:40 PM
