Can anyone help?
Old Feb 5, 2009 | 01:28 PM
PeekinZeke's Avatar
Can anyone help?
I just bought 2 x Powerbass S-12D subs which are dual voice coil and 4 ohms per coil, i have each sub hooked up parallel and the are going to a Power Acoustik SL2-2000 (2channel amp) so each subs has its own channel at a 2 ohm load. correct?
Now my problem is before any of that even takes place I think, when I hook up both RCA's into the amp my amp going into protection mode. Now im not sure if its the Hi-Low converter or if my amp is just crapped out on me. The converter is installed correctly so Im really at a loss of things to do right now, does anyone have any suggestions?
Old Feb 5, 2009 | 02:26 PM
stinkyfisherman's Avatar
Your right each channel sees 2ohms.
So without your rca's hooked up its not in protect? Check your rca's if you have an extra pair try those.
Old Feb 5, 2009 | 07:07 PM
EmperorJJ1's Avatar
huh thats odd. try a mp3 player or ipod with the 3mm to rca and see if it still goes into protect. If not then its either the LOC and or rcas and if so its the amp
Old Feb 5, 2009 | 07:20 PM
PeekinZeke's Avatar
I figured out the problem today I made a huge mistake..... my power wire is blue and ground is red I F@#*'d up and put the power in the ground location and the ground in the power location on the amp. Blew all my fuses but my amp didn't get damaged luckily.
Old Feb 5, 2009 | 07:27 PM
sethallen's Avatar
wow thats crazy...i've never heard of red being a ground wire...
Old Feb 5, 2009 | 08:30 PM
PeekinZeke's Avatar
Ya I've always had my power wire as blue and ground as black but when I bought the cobalt I threw away my old wires and I ran out of black wire and only had red left, so I stuck the red one in the black ones place and forgot about it. I did it so I wouldnt confuse myself but I seemed to do that anyway.
But it all works now and sounds pretty good, now I just need to ahold of some sound deamplifier to stop the rattle.
Old Feb 5, 2009 | 10:11 PM
that will do it. your lucky that nothing got hurt on the amp
Old Feb 11, 2009 | 11:29 AM
PeekinZeke's Avatar
yea i know but thanks a lot for all of your help guys.
Old Feb 12, 2009 | 02:12 AM
EmperorJJ1's Avatar
x2 blew my ppi real quick putting the plug in backwards
Old Feb 12, 2009 | 12:52 PM
Where I work we had our lead installer (at the time) swap power wires on a basslink and messed that thing up, it was classic. Oh and on that same car he arced the battery terminals and shocked the **** out of himself I hadn’t laughed that hard in awhile.
Old Feb 12, 2009 | 09:04 PM
EmperorJJ1's Avatar
lol i arched my battery terminals once. but no shock for me
Old Feb 12, 2009 | 09:34 PM
lucky I dont really wanna feel 800 cca's.
Old Feb 13, 2009 | 02:48 AM
EmperorJJ1's Avatar
lol **** that... i was much more careful when hooking up my kinetiks. god that would have fucked me up good
Old Feb 13, 2009 | 10:12 AM
Oh yea one of those battery would really hurt. I'm gonna plan on not doing that any time soon.
Old Feb 13, 2009 | 01:56 PM
Spun's Avatar
Not that Art seies one
Old Feb 13, 2009 | 11:42 PM
EmperorJJ1's Avatar
no its a power class. but i really want to get 3 of those art series amps. The black A600s
