can i use this amp?
can i use this amp?
Boss NX3000.2 Onyx Series 2-Channel Power Amplifier
ok i know i can use the stock subwoofers wiring to wire this up using the high output option but if i do that can i still run it @ 2ohm on 2 channels running 1500 watts each?
How to wire 2 dual 2ohm subs to 2 ohm for amplifier - YouTube
ok so I found this video and i knew how to do all this but only on a mono amp....he said you could just run it bridged on a 2 chan amp and i though but that would run 3k watts and then i though ok but its running to both subs so it would actually be 1500watts a peice like it should be right?
i just trying to figure out how imma run 1500 watts to each sub on a 2 ohm base becuase they are 750rms and 1500w max aand i want the most outta my bass
would i just run each sub on its own channel but hook their own dual voice coils together and then run a parralle off each sub to thier own channel ?
First off, the amplifier in question is never going to output as much power as claimed- so just forget about that for a minute.
Second- exactly what subwoofers are you going to be using?
For what it's worth- I run a 12" dual voice coil Cerwin Vega woofer in my car getting about 100 watts per coil- so 200 watts RMS to the woofer. That's real wattage. It sounds pretty damn good if you ask me. No real need for more power, especially since my woofer has a very high sensitivity. (Needs less power to be loud)
This is coming from a guy who has and uses regularly up to 3 15" woofers and 4 12" woofers in his apartment at any given time with well over 1,000 watts. (All Cerwin Vega home audio speakers with exception of the 15" Stroker custom home theater sub)
Back on topic lol
Back on topic lol
lol how am i screwed? hopefully your not saying im only gonna get half the power i could have...
just to clarify heres my amp and im pretty sure i can run it at 2 ohm? i mean what would be the problem here?
http://www.sonicelectronix.com/item_...-NX3000.2.html
yup thats what im saying. the only options you have wiring it correctly get half power from the amp. and sadly one of those subs can handle more then the amp can make at full power. It might be worth it to just run one sub at full power if you plan on keeping the amp (which is a crap amp honestly)
i had my amp for sale for a while b ut decided to keep it... the fosgate 1000.1 monoblock which powers my 2 12" P3 subs very well... loud as ****
http://www.rockfordfosgate.com/produ...n_US&p_status=
probably screwed into the panel under the steering wheel. if the knob comes apart you can drill a hole in the shifter panel for a very clean look sorta like this (just fyi this has been redone so it doesnt look retarded anymore and if you plan on doing it you cant put the knob on the right hand side like this pic)
thanks bro!... ya i fucked that one up by not thinking so i had to get another and go again. drilling into it isnt bad really its just i had so many holes to make and did it by hand the first time. so when i went back i measured and now its actually straight
