capacitor questions
Old Dec 21, 2011 | 05:27 PM
the jelly man's Avatar
I would rather buy wire here i dont want to pay for shipping. I need only like two feet anyway
Old Dec 21, 2011 | 10:23 PM
SSSnoop's Avatar
Ever since the rear harness ground issue I saw in my 95 Z28, I do not trust stock or chassis grounds for anything higher than a 200w amp. Simply too much cheap wire, cheap connections and questionable chassis conductivity for my taste. I ran my additional ground through the interior - haven't done one on the 'balt (yet), but I'd suspect that it isn't too difficult to run the wire like I did on a j-body.
If it is easier under the chassis and somebody knows - do tel!!! Save me the trouble of figuring it out when I do run my system!
Old Dec 21, 2011 | 11:21 PM
EmperorJJ1's Avatar
its definatly easier to run the wire inside the vehicle but theres a limit of how much wire should be in the damn thing so i did my grounds outside
Old Dec 22, 2011 | 01:30 PM
So when i redo my ground where should i connect it to?
Old Dec 23, 2011 | 08:55 PM
SSSnoop's Avatar
That's no problem - you can connect it straight to the cable, or, if you want to improve grounding in general to the rear of your car, you can secure it somewhere in the chassis where there's a decent sized bolt or to the stock ground point for your rear, then to your amp. On my Z28, I had a spare hole from where some other old parts connected, and I sanded and used that point as a chassis ground - I even have my ground points for my rear lights relocated there.
Old Dec 24, 2011 | 12:33 AM
EmperorJJ1's Avatar
generally u dont want to reuse a bolt as your ground. since most are just spot welded on the car anyway a direct sheet metal ground is better
Old Dec 24, 2011 | 11:46 AM
How would I go about directly grounding a wire to the sheet metal?
Old Dec 24, 2011 | 04:17 PM
EmperorJJ1's Avatar
using a grounding bolt like rockford fosgate offers is best otherwise just metal bolts or self tapping screws
Old Dec 26, 2011 | 10:10 AM
Twoozofjuice's Avatar
was reading this post because the setup i have pretty much makes my lights dim as hell but not flicker which im guessing is just for the power that theyre actually using and began wondering if there was anything actually bad with that? its a dumb question but i dont know much about my cars electrical system so just thought id ask. running a pioneer headunit a kenwood 1800w at around 900 rms and 2 kicker l5s at 450 rms each
Old Dec 26, 2011 | 02:53 PM
Didnt think kenwood was a bad brand
Old Dec 26, 2011 | 03:01 PM
  #36
EmperorJJ1's Avatar
its not... sorta
but to answer ur question yes dimming can be bad but it really all depends
Old Dec 26, 2011 | 05:11 PM
  #37
SSSnoop's Avatar
To get an idea of the power draw of an amp, I've heard of this equation - multiply the number of channels by the RMS watts per channel, multiply it by 2 to take into account the power loss/inefficiencies (a rough estimate, but it works), then divide by 13.8 volts (average alternator voltage). Divide by 3 for average power required for the amp and you get an idea of how many amps your amp takes. If I did the crayola math right, you're pulling 87 or so amps on average, and assuming the 'balts alternator is 110 amps, you can see you're taxing the power capacity of your balt. It isn't surprising that you will see headlights dimming, even with good grounds and adequate cabling. A capacitor can help, but still, I think you'll be drawing from it a lot. After around 800 watts, I'd consider upgrading the alternator to a higher power unit - or driving around without the headlights on!
Old Dec 26, 2011 | 06:43 PM
  #38
brickloaf's Avatar
this thread it way to long for such an easy solution....if you dont want headlight dimming either do the big 3 and get a deep cycle battery or buy HID's....never had a headlight flicker on around 2k rms since i installed HID's...
Old Dec 26, 2011 | 09:47 PM
  #39
SSSnoop's Avatar
I've actually not had a problem after I put in a 130 amp (or higher) alternator in my high-wattage cars I used to do! Its a heck of a lot less expensive and time consuming than swapping out the innocent parts!
Then again, those cars had welding cable running to the back to supply the juice......
Old Dec 27, 2011 | 12:46 AM
  #40
EmperorJJ1's Avatar
lies. weren't u having problems with ur hid kit for a while?
but yes a functional hid kit will fix dimming issues
Old Dec 27, 2011 | 12:53 AM
  #41
brickloaf's Avatar
ive been having HID issues for like a year even with my brand new projectors but it completely stopped dimming
Old Dec 27, 2011 | 12:58 AM
  #42
EmperorJJ1's Avatar
lol i know that but had to give u some ****... i might get around to doing gen 1 retrofits this year but idk. if i do it its gonna be as all out as my system so gonna suck without a shop to work in
Old Dec 28, 2011 | 10:51 AM
  #43
What is the big three?
Old Dec 28, 2011 | 01:24 PM
  #44
EmperorJJ1's Avatar
upgrading batt ground alt power and alt ground
Old Dec 28, 2011 | 02:39 PM
  #45
What would upgrade power? Battary?
Old Dec 28, 2011 | 11:41 PM
  #46
EmperorJJ1's Avatar
what do u mean upgrade power?
Old Dec 29, 2011 | 11:13 AM
  #47
Oh i read your post wrong sorry. How do i upgrade alt power?
Old Dec 29, 2011 | 12:20 PM
  #48
EmperorJJ1's Avatar
run of wire from the alt + to the bat + or from the alt+ to the fusebox and from the fusebox to the batt+ (how its ran stock)
Old Dec 29, 2011 | 01:14 PM
  #49
Is that what the two wires are in the picture you postrd? Are those going to your alt?
Old Dec 29, 2011 | 11:23 PM
  #50
EmperorJJ1's Avatar
no those arent part of the big 3 hence why i said that may or may not have even made an effect. those are from my battery grounds to the alternator grounds
