Car Audio Sub HELP!
Old Mar 7, 2010 | 06:22 PM
Garret's Avatar
Unhappy Car Audio Sub HELP!
Ok I've asked local shops, other cobaltss.net members, well I've asked a lot of people. If you know anything about car audio please read this and help me out.
My system: stock h/u, 2 apline type r 12", alpine m850 amp. My amp is grounded to the same place as the battery is grounded. The amp gets signal from my rear speakers through a line output convertor, that too is grounded in the same place.
Now the problem is that at high volumes the subs will cut out, the amp stays on. By high volume I mean on the stock h/u if the fade is set to the middle and the bass is set high, when I turn up the volume anywhere past 3/4 the subs will stop playing. If I turn the fade to about 3/4 towards the front, then subs will not cut out, but the bass will be quieter.
If anyone has ANY idea what is going on here pleeeease help me out.
Old Mar 7, 2010 | 06:29 PM
Cefaln452's Avatar
first off. dont have your bass set on high as you may be overloading/distorting your system. second off. your amp is probablly not tuned correctly, and is shutting off and going into protect... subs could be hooked up wrong, could be wrong ohm load for the amplifier, could be a bad amp.... there are many possibilities that could make this happen
Old Mar 7, 2010 | 06:34 PM
Garret's Avatar
I forgot to mention I had this same system in my previous car with no problems. The amp is tuned properly. , also I've thought of a few more clues. The subs cut out more noticeably when there are high treble tones in the song. For example a metal song it tends to cut out on guitar solo, and on rap sons it will not cut out if there are no high treble type of sounds. Hard to explain.
Old Mar 7, 2010 | 08:25 PM
chudson91's Avatar
ok well play it again let the amp get a lil warm then blast it and when it cuts off go see how hot it is that will let u no if its ohm load is wrong ibut it could be a million things rule out one after another and if u need a head unit i have a dash kit
Old Mar 8, 2010 | 02:06 AM
Garret's Avatar
I'll give that a shot, but I doubt that is the problem, as this never happened in the old car. Any other ideas anyone?
Also you said if I need a H/U, could the line out convertor have anything to do with this? Don't get me wrong the subs can play fairly loud now, I don't know if it's worth buying a whole new h/u just for a bit more volume. And I don't wanna lose my steering controls with a hu.
Old Mar 8, 2010 | 04:15 PM
Garret's Avatar
morning bummmmmp
afternoon bump.. nothing eh?
Old Mar 8, 2010 | 06:00 PM
chudson91's Avatar
are you running stock head unit
Old Mar 9, 2010 | 12:18 AM
EmperorJJ1's Avatar
whats ur low pass set at?
Old Mar 9, 2010 | 10:04 AM
BlueBalt1113's Avatar
alright dude so for stock h/u there is a certain connector that you need to buy i cant remember where though. You really should look into a new aftermarket h/u and the cutting out will stop
Old Mar 9, 2010 | 02:34 PM
Garret's Avatar
Yes it is the stock h/u. why does it cause the clipping? and the low pass i think its at 50 hz, might be 40
Old Mar 9, 2010 | 03:44 PM
395 plus's Avatar
Try raising the low pass crossover frequeny to 100 and see if it still does it.
Old Mar 9, 2010 | 08:59 PM
tpete763's Avatar
hmmm, not trying to jack the thread, but a buddy of mine kind of has an issue like this in his car. But his problem is with the whole system not working past a certain volume. He has switched headunits as well and still the same problem... any thoughts???
Old Mar 10, 2010 | 01:55 AM
EmperorJJ1's Avatar
probably wrong impedance or a blown woofer
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
Turbo6
Sep 24, 2015 04:15 PM
