Cigarette Lighter Not Working
Old Jun 2, 2011 | 07:42 PM
JshLnsctt's Avatar
My cigarette lighter directly under my stereo hasn't worked since I got my car. I've read around the forums but can't seem to find anything that will help. I read that it's on with the OBD? My OBD port works fine. My other cigarette lighter also works fine. I've looked in both fuse boxes and found no blow or missing fuses that seem like they could be the cigarette lighter. Any suggestions? Should I replace it?
Old Jun 2, 2011 | 07:53 PM
reefone's Avatar
pop off the trim and make sure someone didnt unplug the wires to it
Old Jun 2, 2011 | 08:03 PM
JshLnsctt's Avatar
I took off the drive side kick panel and felt up in behind and the wires all led right to it. Is there a way to pull it out without breaking it so I can check the wires for voltage? Kind of hard to get at it from behind
Old Jun 2, 2011 | 08:12 PM
c4w18's Avatar
pull up your shifter trim and the rear cupholder trim and pull up on the console trim outside of the shifter....move it back a little bit and you should have easy access to the cig lighter plug.....also, just because a fuse doesn't look blown doesn't mean that the contacts aren't shitty....use a meter to check the fuse.
Old Jun 2, 2011 | 08:19 PM
reefone's Avatar
get to the wires like this
http://www.twmperformance.com/manual...all-manual.pdf
Old Jun 2, 2011 | 09:26 PM
JetBlackSS's Avatar
Just replace the fuse. much easier and only costs like $5 at most for package of fuses. Mine did same thing. Easier then tearing all apart if you dont have to. You should have extra fuses in empty spots from factory. Check manual for location of cig lighter fuse.....it should be in the box under the hood.
Old Jun 2, 2011 | 10:02 PM
JshLnsctt's Avatar
I checked the fuses with a fuse tester
Old Jun 2, 2011 | 10:44 PM
c4w18's Avatar
take a meter and make sure one side of where the fuse plugs in is getting 12 volts....
Old Jun 3, 2011 | 03:29 AM
EmperorJJ1's Avatar
probably unplugged i think both of them are on the same circuit
Old Jun 4, 2011 | 11:16 PM
JshLnsctt's Avatar
I found a ton of articles online and on here where only the one was working, and they said it was on a different circuit with the OBD power. I just haven't found anything helpful toward fixing it yet.
Old Jun 5, 2011 | 02:20 AM
Hammbones's Avatar
I just fixed my lower lighter socket. Apparently the person who owned it before me modified the lower lighter for the 12V power supply and didn't splice it back together properly. The LOWER lighter is on a different power route than the upper outlet. The upper outlet is tied into the OBD harness. The best thing I could recommend if you can't get it resolved by fixing the issue outright is to splice into the lower one with wire blades. A bag of 8 Male / 8 Female 16ga wire blade connections are $2.79 @ Radioshack. I would also recommend using a bit of solder to make sure you have good connections.
Good Luck!
Old May 1, 2012 | 08:06 PM
jaydd73's Avatar
I HAD THE SAME PROBLEM!
HERE IS WHAT I DID...
After taking the car to my dealer the cigarette lighter below the climate control stopped working, but the other lower one was still working.
I checked the fuses in the manual and it says there are two fuses. The lower cigarette lighter seems to be wired to the same fuse as the light in the trunk which protects the driver in the circumstance that one burns out. This way you still have a way to charge something.
Therefore
1. under the hood open the fuse box
2. Locate the 15A fuse labeled LTR (this is the cigarette lighter below the climate control)
3. See if it's burnt, or better off testing the continuity with a multimeter
4. If it's burn replace it.
NOTE: If your lower right cigarette lighter doesn't work find the 20A fuse labeled TRUNK/ OUTLET, and repeat steps 3 & 4.
Hope that helps.
Good luck
J-ME
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
