clarion touchscreen
Old Jul 5, 2009 | 10:40 PM
fielder87's Avatar
clarion touchscreen
Hey all just baught a clarion touchscreen.Was wondering if I actually had to buy the harness adapter(06 cobalt lt coupe).If not what are the downfalls.As it sits now I quick conectored it to the harness individually, and manually found speakers,ground,12v,ect...Thanks
any body know any serious issues?I see one dark green wire i believe it is,when i touched the + of the speaker wire to it kicked on my ABS light and made others go out.It still is not hooked up.thanks
Old Jul 5, 2009 | 11:01 PM
mikelpn's Avatar
Do you have onstar or pioneer?
Old Jul 5, 2009 | 11:53 PM
ctcsoccer7's Avatar
use the xsvi-2103 harness, retaines everything even RAP, retained accersory power, radio stays on until you open the door
Old Jul 6, 2009 | 12:14 AM
jschatte's Avatar
you just need the cheap harness you can find at walmart or whatever.
Old Jul 6, 2009 | 12:15 AM
jschatte's Avatar
RAP has nothing to do with the radio...
Old Jul 6, 2009 | 12:44 AM
EmperorJJ1's Avatar
well the gm lan is a purple wire i believe. either way your tapping something that needs not be tapped. Personally i wouldn't attempt to hard wire it for no reason. buy the cheap harness (70-2103)for 20 bucks or the expensive one for 50 (xsvi-2103) so you don't have to worry about it.
also remember there isn't an ACC in that harness
what he meant was the rap for the radio. since finding an acc wire that has the rap too isnt always easy
Old Jul 6, 2009 | 01:42 AM
mikelpn's Avatar
I got my xsvi-2103 on ebay for $14. If you can find it for under 20 spring on it if not like he said go with the cheap one and run a line to the fuse panel.
Old Jul 6, 2009 | 01:51 AM
jschatte's Avatar
hmm.... I found one pretty easily when i was wiring up my deck
Old Jul 6, 2009 | 02:34 AM
EmperorJJ1's Avatar
like i said it isnt always easy. meaning that it is easy in certain cobalts.
Old Jul 6, 2009 | 09:54 AM
fielder87's Avatar
k thanks all ill look on ebay everybody around here(ontario,ca) and saying it 150$. just like my womens aero.so i cut the harness and said ***-em.as long as there is no serios problems then i wont but a harness the deck works fine now.thnaks.
Old Jul 6, 2009 | 10:06 AM
EmperorJJ1's Avatar
lol nope thats for 07+
hopefully you did get it right
Old Jul 6, 2009 | 10:13 AM
fielder87's Avatar
Thats good news.thanks
I got it right it works beautifully.lol.do you know what the dark green wire(off pin clip to itself)does,it is the one that set off my abs light and stuff and others kicked on?
Old Jul 6, 2009 | 01:15 PM
ctcsoccer7's Avatar
wow, you have no idea how wrong you are, RAP controls the power going into the radio , and with the XSVI-2103 it would allow you to have the radio on even with the key off , untill you open the door. Before you say something silly like that , get your facts straight.
McKeough
May 14, 2008 06:06 AM
Ekset
Dec 2, 2007 07:12 AM
simpleman68
May 4, 2007 08:20 AM
riscphree
Jul 7, 2006 07:02 PM
