digital gauge cluster?
No there isn't. It would take a lot of programming to get one to work. It would have to be completely custom made. Technically you could do it by building a carPC and putting the screen where the cluster is and running HPTuners. I believe there is a part of HP tuners that digitally displays "gauges"
actually not so hard to accomplish. 07+ cobalts can poll OBD data MUCH faster than previous Cobalts and older GM's in general.
OBD interface module fed into a carPC and then simply polled via an application will do the job perfect. Not hard at all.
Without a carPC, it'd be more difficult. :-P
could build a OBD/CAN interface mini-box and push that data to a monitor.
i personally like the PC route. a lot less guess work.
i've been on the hunt for a while for a new non-touch screen for use in the gauge cluster as an overlay. i'm unsure if i'll do this before I switch to more of a distributed carPC model. but I can tell you I've hooked the obd module up and had my carPC polling like mad on the main center monitor just fine.
Forget honda's digital speedo. New range rovers, and mercedes have a digital screen. Like it's just an LCD screen in the dash no gauges and it shows the speedo and tach. Possibly other stuff, but I don't play around with other peoples cars. But it's freakin awesome. Reminds me of a glass cockpit like in planes. If I could take the gauges out and replace with an lcd screen to display all the gauges I so would.
