Door speakers in an LS?
Old Jul 11, 2008 | 10:56 AM
polarbair's Avatar
Has anyone done a "how-to" on replacing door speakers? Want to install an aftermarket HU and would like to upgrade all the speakers. The back ones have been covered, just curious about the front?
Old Jul 12, 2008 | 09:27 PM
ljblue's Avatar
I dont have a how to, but there is one on removing the door panels. I just did mine about a week ago. Its pretty easy. Id recommend speakers from Crutchfield, since they give you everything you need.
Old Jul 13, 2008 | 09:54 PM
biniecki's Avatar
I just got some audiopipe 6.5 and 6x9 speakers this weekend and will be installing them into my LS. I can make a how to if you want. For right now I am just replacing the speakers but will eventually get a new headunit and hook the speakers to an amplifier.
Old Jul 13, 2008 | 09:59 PM
EXsoccer1921's Avatar
just remove the door panels. then unscrew the speakers. and the factory speakers in pretty much all cars have a plastic clip that goes onto the speakers and has the wires attached to the clip. just cut that off and take off the insulation to the wires, then you're good to go
Old Jul 13, 2008 | 11:40 PM
EmperorJJ1's Avatar
you still would need a bracket of some type if you want to do it right. Supposively a guy at the shop made some 6.5s fit in his gf's ls no bracket but i made one when i was putting them in my ex's ls. If the speaker isnt sealed off its going to sound worse
Old Jul 14, 2008 | 01:34 AM
i was just stating the cliff notes version haha. i know my sound stuff don't worry
Old Jul 14, 2008 | 06:21 AM
JayB1127's Avatar
Can someone actually write a complete how to.....I have a set of 6 1/2 Infinitys I want to put in......
Jay B
Old Jul 14, 2008 | 10:48 AM
Brraaapp's Avatar
Jay B
I put 6 1/2 infinity references in last year. What I did was after I had door panel off etc. I took the speaker out and cut the tabs in the stock speaker off and totally gutted the stock speaker. Then I put the new speaker in the stock housing. fits awesome. But some people said I might have weather issues like rain/snow with it not being sealed right. But no problems here.
Old Jul 14, 2008 | 03:03 PM
EmperorJJ1's Avatar
nah the only really element issue you may end up with is a broken speaker but that has nothing to do with how you mount it. Ive had my door panel off with no speaker and when i washed my car there was definite water in the door but nothing really entered the cabin. there isnt really much harm that can be done
Old Jul 15, 2008 | 02:32 AM
JayB1127's Avatar
I bought these Infinitys for a S-10 and I had them in under 5 hours, truck was hit and totaled, so I pulled them and everything else out, and now Im working on my car and can use 6 1/2's again. Will putting the new speaker in the stock housing? and your said Broken speaker, how?
Jay B
Old Jul 15, 2008 | 02:45 AM
EmperorJJ1's Avatar
yes 6.5s will work with a bracket
Old Jul 15, 2008 | 02:56 AM
JayB1127's Avatar
Where can I buy/find a bracket? Like a local place, Best buy/ Circuit city?
And when you refer "sealed off" Whatd do you mean?
Jay B
Old Jul 15, 2008 | 03:04 AM
JimmiLS05's Avatar
I used the factory bracket, just modded it, but like it was mentioned if you buy your speakers from Crutchfield they will send everything, brackets , harnesses and instructions.
Old Jul 15, 2008 | 03:10 AM
JayB1127's Avatar
I already own the speakers.......
Jay B
Old Jul 15, 2008 | 03:14 AM
EmperorJJ1's Avatar
how long can u wait? hopefully soon i will be getting rid of mine
Old Jul 15, 2008 | 11:19 AM
biniecki's Avatar
I just installed my new speakers last night. I didnt make or modify the brackets yet tho. For now i just drilled some new holes and mounted them to the door. Its not sealed all the way around but it still sounds good right now. Eventually I will get around to new brackets.
BTW does anyone know what the stock output is from the radio to the speakers? Im looking for a wattage? My new speakers don't sound as loud but are a lot clearer. I think its because I have not amped them yet and the stock radio doesnt put out very much to the speakers. My 6.5 doors have an RMS of 125W each and the rear 6x9 the RMS is 250W each. Haven't installed the rears yet, waiting for the weekend
Old Jul 15, 2008 | 04:24 PM
JayB1127's Avatar
All I do is wait, lol.....They have been in my locker at work for 2 weeks now, and Ive yet to atempt to try to put them in, just trying to gather all the correct info and parts I need first.
Jay B
Old Jul 15, 2008 | 11:08 PM
EmperorJJ1's Avatar
then either call around to see if someone makes a braket or hack ur stock speakers up. try chevy, metra, scosche
Old Jul 15, 2008 | 11:14 PM
Brraaapp's Avatar
sorry im lazy. ill try and take mine appart tomm for some pics.
Old Jul 16, 2008 | 02:50 PM
cobaltmatt23's Avatar
how about a how to on installing 6.5's in your doors with the aftermarket grills attached to the door
Old Jul 16, 2008 | 06:21 PM
biniecki's Avatar
I was thinking about putting my aftermarket grilles on but it looks a little involved. The door isn't flat enough to just slap them on so it looks like you would have to use a dremel and cut the old area out and then try and use bondo or something to mold the new grill into place
Old Jul 17, 2008 | 05:19 AM
EmperorJJ1's Avatar
depends on the grill. if its closed enough you can get away with cutting a hole and mounting the grill on the panel itself.
Old Jul 17, 2008 | 06:45 AM
Buckweed's Avatar
IIRC it is 9watts
Old Jul 18, 2008 | 11:03 AM
Preowner's Avatar
I'm sure the stock speakers are a slightly more efficient dual paper cone design. Coaxials use a bass blocking cap for the tweeter which sucks up a little power.
"Loudness" can also be percieved with distortion. Better speakers you tend to not realize are playing as loudly. Untill you get blasted the next time you start the car
I thought someone put a post in the how to section for non pioneer system door speakers. But I think they did hack up the stock speakers for the brackets.
Old Jul 19, 2008 | 12:50 AM
EmperorJJ1's Avatar
if by more efficient u mean cheaper then yes that is correct
dasoftest
Sep 29, 2015 02:14 PM
xxenjoi11
Sep 29, 2015 12:36 PM
brickloaf
Sep 25, 2015 09:10 PM
dieGone
Sep 23, 2015 10:20 AM
