dual 12 inch sub boxes
Old Aug 29, 2008 | 07:47 PM
brickloaf's Avatar
I just got a dual 12in sub setup with the box, but cannot for the life of me get it in the trunk. the trunk opening inst big enough, and i couldnt get it in from the back seats. how am suppose to get them in there??
any help appericated
Old Aug 29, 2008 | 07:50 PM
EXsoccer1921's Avatar
is it a q-logic box?? i bought one for my sisters LS and i had to put it in through the back seats W/O amp and subs installed. i think i had the openings for the subs facing down when i slid it in. it was tough, but i got it. once its in theres enough room to flip it back up and more it around. i was able to move it 360degrees once it was in there
Old Aug 29, 2008 | 09:00 PM
brickloaf's Avatar
its not a qlogic, its a sony box but the dimensions are
height: 16.1
width: 32
depth: 18
if that helps
update
i took out the subs and just tried to put the box in...no luck
the only thing i can see working is if i took the back seats out to put it in...
any other ideas?
Old Aug 29, 2008 | 09:01 PM
get a new box, cause i don't think thats gonna fit even if you take the seats out completely
originaladrian's Avatar
take out the back seats, when i had my 15 i did tht, its not hard
i'm too lazy. so you can do it. but check those dementions against the qlogic ones
Old Aug 29, 2008 | 09:56 PM
xyankees214x's Avatar
i takes literally 5 seconds to tkae the back seats out
seriously. the top push to one side and pull up and the bottoms push down and towards the back of the car and theyll come out.
thats what i had to do to fit my l7 box
Old Aug 29, 2008 | 09:58 PM
umm, mine werent so simple, but not hard
theres 2 bolts, then u have to wiggle them around to get the metal bar on the bottom over the plastic on the side of the car.
Old Aug 29, 2008 | 10:00 PM
finhead's Avatar
I made a custom enclosure, but had to cut it in 2 pieces to get it in. Then I just reassembled it in the trunk. Had to actually finish all the trim pieces in the trunk. I brought it in through gthe back seat.
Old Aug 29, 2008 | 11:07 PM
brickloaf's Avatar
i took out the back seats, still no luck, looks like ill be making a return tomorrow
Old Aug 29, 2008 | 11:13 PM
creedin's Avatar
youre mental... my box is 34 x 14 x 12... i know its not the same, but i literally had no problem through the rear trunk opening or the rear seats... remove the bottom of the seats, then the back seats flip down about another inch... itll be tight but it should fit with it up 16", but put in on the driver side back seat otherwise youll hit a bolt
Old Aug 29, 2008 | 11:38 PM
brickloaf's Avatar
mine is 2 inches taller than yours, if mine was 14" tall it would already be in there
Old Aug 30, 2008 | 03:29 AM
EmperorJJ1's Avatar
too wide and too tall. stock opening with everything removed (i would know) is 30" wide up top (37" on the bottom) and 16" tall
If you remove the seats and mounting bracket there's a slim chance you can literally kick it in there but don't expect ur carpet to be intact when ur done
Old Aug 30, 2008 | 10:47 AM
madlion's Avatar
i installed a 13w7 with a subzero box in my old civic. had to pretty much gut the interior to get it in there. one plus to a tight fit is no one will be able to steal it easy. they may razor blade the surrounds though if they get frustrated.
Old Aug 30, 2008 | 10:49 AM
El Mariachi's Avatar
Ya, installing my subs, amp, and sterio deck was a pain in the ass for my cobalt ls lol
Old Aug 30, 2008 | 11:06 AM
creedin's Avatar
i know i said that, take off the seat, you can get it in there
dennis69
Oct 20, 2015 04:49 PM
cw383
Sep 30, 2015 12:41 AM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
c_m_shooter
Sep 27, 2015 04:40 PM
