Easiest Switched Power (for non-sunroof cars)
I searched through the forums on where to get switched power to run my xm sattelite radio on my dash. I did not feel like ripping stuff apart to tap into an outlet, or piggbyack it onto something of importance. My LT was not equipped with a sunroof and i noticed it has a 15A fuse for the sunroof on the fuseblock. I pulled the fuse out and cut a connecter in half so it would fit on the side with power, ran my own 5a inline fuse and now i have power to my radio on a dedicated circut. Just thought i would share this, and sorry if it is old news. I think this is the easiest way to get switched power for acessories.
on mine the fuse was there and there was power when the key is on... mine is an 08 LT, different packages may be different.i would have to check again but i beleive the power is on the right hand side not the left.
there are a BUNCH of switched sources, tap one from ur inside fusebox
people need to correctly get a switched source instead of ghetto rigging everything
Last edited by originaladrian; 11-14-2008 at 01:33 PM. Reason: Automerged Doublepost
i just put a add-a-fuse in the wipers. i want a fuse that is on accessory only cuz i want the radio to stay on until i open the door.
i belive there are 4 if not more empty fuses in the 2,2 that are switched. all switched sources are ACC sources. they turn off when you open ur door, not turn off car.
when i put a fuse inthe sunroof spot it just fell out....it didnt like stay in and there was no power so idk. what others are there?
twilson380
09-14-2015 10:52 AM
