Fan help...
Old Oct 25, 2008 | 08:14 AM
red06s/c's Avatar
Fan help...
Ok i installed a manual on.off toggle switch for my fans. now i put a 20a fuse in and it poped itthe first time. put a 25a fuse in and they work 3-4 times before blowing. So anyone thing a 30-35a fuse would be safe? Or do you know what the amps are on the fans?
Old Oct 25, 2008 | 08:16 AM
MP Cobalt's Avatar
If that dont work you might have to go with one of those little cylinder fuses.
Old Oct 25, 2008 | 08:17 AM
JimzSS's Avatar
Don, what is the amperage of the stock fuse? If you are running both fans I would guess it would be over 40 amps. Don't blow it up before you Dyno it! Hahhaha
Old Oct 25, 2008 | 08:19 AM
red06s/c's Avatar
ok, so ill try a 30a fuse and hopefully it dont have a melt down lol. im spose to go to the dyno at 10 and i wanted these to work. thanks
I dont kno, i fallowed a how-to on another site and they said a 20a fuse, so thats what i did. I think a 30a will work cuz the 25a worked a few times...and thats all i have left for fuses lol.
JimzSS's Avatar
a fuse is a fuse is a fuse... CONfused?
Old Oct 25, 2008 | 08:20 AM
red06s/c's Avatar
what time u leaving to head up there?
Old Oct 25, 2008 | 08:21 AM
MP Cobalt's Avatar
just go up the line until it don't melt or blow.
JimzSS's Avatar
I am gonna leave around 9ish
Old Oct 25, 2008 | 08:22 AM
red06s/c's Avatar
Me 2.
Old Oct 25, 2008 | 08:23 AM
JimzSS's Avatar
I need coffee
Old Oct 25, 2008 | 08:28 AM
red06s/c's Avatar
I need coffee
lol, well ima go put that fuse in and get ready to bounce...tom tom is leading my way lol.
Old Oct 25, 2008 | 08:29 AM
JimzSS's Avatar
get off 8 north at 303 and go straight across 303, thats chittenden...about 1/2 mile up on right hand side in a gated industrial park.
Old Oct 26, 2008 | 05:11 PM
EmperorJJ1's Avatar
how did you wire the switch? the fan shouldnt be popping the in car fuses
Old Oct 26, 2008 | 05:16 PM
JimzSS's Avatar
he was wiring an in cab on/off switch so he could turn his fans on when he needed to
Old Oct 26, 2008 | 07:01 PM
EmperorJJ1's Avatar
right but depending on how much current the fan pulls and what switch you use could be the reason for fuses popping. If he put the switch on the power wire of the fan which is what im assuming it may be trying to pull too much power thru the switch itself. A better method would be wiring a relay and using the switch inline.... then the switch itself would have virtually no power running thru it.
Old Oct 26, 2008 | 07:05 PM
red06s/c's Avatar
We ran a hot wire from the post inthe fuse box, to the toggle switch. we jump in the fan control #2 that comes on with the a/c. I think something along thos line. anyways i put a 30a fuse and it hasnt blown yet so i think its fine now.
Old Oct 26, 2008 | 07:23 PM
JimzSS's Avatar
so essentialy you are jumping the relay and running the current through the switch?
Old Oct 26, 2008 | 07:25 PM
red06s/c's Avatar
i think it will be easyer to pm u the link for it lol. i dont kno nothing about this electical stuff lol.
Old Oct 26, 2008 | 07:37 PM
EmperorJJ1's Avatar
no the exact oposite jumping the switch and using the relay. Like i said i'm not sure on how much juice is running thru the fan but i bet its more then a normal switch can "handle" hence getting hot and popping the fuse.
Old Oct 26, 2008 | 07:40 PM
red06s/c's Avatar
started with a 20a, popped it. addeda 25a fuse and it worked 3-4 times then popped. put a 30a and has worked 10+ times now and hasnt popped, and jim (jimzss) has seen they do work with the switch.
Old Oct 26, 2008 | 08:25 PM
EmperorJJ1's Avatar
now what fuse are you talking about BTW? the actual mini fuse in the fuse box or your own external fuse? You should never put a bigger fuse in the fuse box then what was previously in there but if its your own external fuse then you can fuse to the "melting" point of the wire guage.
Old Oct 26, 2008 | 08:35 PM
red06s/c's Avatar
its a mini fuse, but its a external fuse that we added.
Old Oct 26, 2008 | 08:54 PM
EmperorJJ1's Avatar
what guage wire did you run?
Old Oct 26, 2008 | 08:55 PM
06superchargedbalt's Avatar
Hey!! Just what I was looking for...where do you find that toggle switch for the fans like that?!
Old Oct 26, 2008 | 09:14 PM
red06s/c's Avatar
12awg or avg or whatever it is lol
just a normal toggle with, i got one that lights up when the fans are on.
