Front Speakers are not working??? AH
Old Jun 29, 2010 | 12:29 PM
1_quick_balt's Avatar
Exclamation Front Speakers are not working??? AH
My passenger side door speaker used to work half the time and the other half it didn't.... Sometimes if would turn the volume up or down i could get it to work...
but now they stopped completely.. and now i cant hear my turn signals... four ways... when i leave my lights on... or keys in the ignition since the sound comes of of those speakers... what should i do???Where should i start??
Any ideas? thanks so much!
Old Jun 29, 2010 | 12:31 PM
EcoTecDriver's Avatar
I Just went through the exact same thing, it would go out and stay out, then randomly go on...I 1st thought it was a connection issue, and my chime went off too....buts its just the speaker dying...after I replaced them, instant fix
short version
Your speakers are dead/dying....just replace them...problem solved.
Old Jun 29, 2010 | 12:35 PM
really?? thats crazy... i know you have to take the inside of your door off.. is it hard to replace them.. i was thinking there were difficult?
Old Jun 29, 2010 | 12:41 PM
Very Easy stuff
pop the cover behind the door handle lever, there is one screw
pop the cover inside the other door handle where your switch's are. remove the other screw, disconnect the harness's and remove the trim.
use a towel so you dont scratch your paint and pry along the edges of the door panel...
its now removed
I found the best tool to remove those plastic plates inside the door handles, is those paint can openers they give you for free after buying a gallon can of paint.
also
You need to clip off the old connector and just crimp on a new one, very basic stuff, You will have no issues doing it, I even added tweeters to mine.
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jmelton327
Sep 26, 2015 10:04 PM
soaxin
Sep 26, 2015 08:39 PM
