Have a few question about my amp CAP!
Old May 13, 2008 | 03:45 PM
KillerBee's Avatar
Ok first i got my amp kit and there was this little wire with a little blue thing in it what is that for? Next do i put my fuse between the battery and cap or cap and amp? and does anyone have a pic of there cap set up so i can see?
and do you need to charge the cap?
Old May 13, 2008 | 03:49 PM
b_faulk75's Avatar
That little thing is a resistor, it is used to charge the cap, so yes you do need to charge it. Put the fuse between the battery and the cap, as close to the battery as you can. Hook up your ground wire to the cap, then hold the resistor in between the positive wire and the cap positive input terminal, for a minute or so, that should do it.
Old May 13, 2008 | 04:17 PM
bgbearcatfan's Avatar
if you don't charge it, be prepared for some big sparkage
Old May 13, 2008 | 06:47 PM
KillerBee's Avatar
how do i charge it with that little wire and how long exactly i am new to these caps lol
Old May 13, 2008 | 08:15 PM
make sure its grounded, then connect the power cable to that little resistor, and touch the other end of the resistor to one of the positive terminals on the cap, and i believe once that cap reads the normal voltage coming from the battery then you can just hook it up normally. I'm sure emperror will come on here and correct me if im wrong
forgot to mention, be careful because that resistor is prolly gonna get pretty hot
Last edited by bgbearcatfan; May 13, 2008 at 08:15 PM. Reason: Automerged Doublepost
Old May 13, 2008 | 08:25 PM
originaladrian's Avatar
Old May 13, 2008 | 08:30 PM
KillerBee's Avatar
yeah i will wait for him to chime in but what you are saying is ground the cap then use the power wire from the batter that is hooked up connect the little wire and the power wire and touch the postive terminal on the cap until it reads what voltage? I have hooked up my amp and everything and it works i just need to connect my cap but i wanna do it right first
Old May 13, 2008 | 08:32 PM
ya charge ur cap witht the resistor in-line till 12V.
now, you CAN charge it just by connecting it but the huge power jump will cause some sparks and might damage something.
Old May 13, 2008 | 08:36 PM
Well i was always told once it levels off.. I think you will probably get into the low 13's voltage wise.. You'll know because the voltage will stop climbing
Old May 13, 2008 | 08:38 PM
KillerBee's Avatar
so which way to do it with out harming anything
Old May 13, 2008 | 08:41 PM
You definitely need to charge it first. Don't take any chances
connect ground, then have the resistor in line between the cap and +12V, the cap will charge slowly this way.
many people will recomend u put the resistor IN PLACE of ur main system fuse.but i never did tht...
hold the resistor with pliers, it will get hot
Old May 13, 2008 | 08:42 PM
Red2.4SS's Avatar
I dont even trickle charge my cap anymore. Just slap the connector back on the battery. Bigger spark but its been fine.
Old May 13, 2008 | 08:43 PM
lol iv done tht a couple of times... its fun
Old May 13, 2008 | 08:46 PM
KillerBee's Avatar
ok so i connect the ground on the cap connect the resistor to the postive on the cap then touch the power wire from the battery to the other end of the resistor until the cap stops raising number wise does it matter which end goes where on the resistor? and my cap is 1.8 fraud so how long with this take to do this?
Old May 13, 2008 | 08:49 PM
it shouldnt take long at all.
if this is something ur gona do often i would build a charge cable for it.
take thick low guage wire and add a 12v audio fuse inline and put the resistor in place of the fuse
the resistor should work both ways
Last edited by originaladrian; May 13, 2008 at 08:49 PM. Reason: Automerged Doublepost
Old May 13, 2008 | 08:50 PM
KillerBee's Avatar
no if i do this one time it will be fine as long as its hooked up right? i dont have to do it all the time do i
Old May 13, 2008 | 08:52 PM
yah minute or two tops
correct
Last edited by bgbearcatfan; May 13, 2008 at 08:52 PM. Reason: Automerged Doublepost
KillerBee's Avatar
it dont keep a charge once you connect it to the damn battery?
Old May 13, 2008 | 08:53 PM
no i was referring to charge time
Keep it hooked up and your fine, you dont have to charge it everytime you start your car or anything
Last edited by bgbearcatfan; May 13, 2008 at 08:53 PM. Reason: Automerged Doublepost
ya u should be fine unless u drain ur cap somehow by disconnecting it from ur system. but u could leave ur car off...forever...and be fine. think of it exactly like another battery, just very fast acting.
Old May 13, 2008 | 09:00 PM
b_faulk75's Avatar
Stop worrying and do it man!!!
Old May 13, 2008 | 09:03 PM
KillerBee's Avatar
i will i am going to do it tomorrow. I hooked up my 1000 kenwood amp and p1 subs today straight to the battery. I wanted to hear the **** lol. But i will charge my cap tomorrow or what not.
Old May 13, 2008 | 11:33 PM
EmperorJJ1's Avatar
ya charge the cap just as ur installing the whole system. and im not sure wtf but thats sorta ghetto. i got a whole lil circuit board with an led and all to charge my old fosgate cap. but the resistor works
Old May 13, 2008 | 11:42 PM
KillerBee's Avatar
so i do as stated above or what i was waiting for you to chime in lol
