Help!!!!
Old Nov 16, 2012 | 10:56 AM
tyler.frederick23's Avatar
Help!!!!
Alright, I've searched and searched, and have had no luck.... I want to wire my new fog lights (since I don't have a switch inside) to my low beams because they only come on at night... Any help is appreciated. Btw I'm a novice when it comes to wiring things up... I've done speakers, and a aftermarket DVD player... But that's as much experience as I have
Old Nov 16, 2012 | 11:14 AM
SunburstSS's Avatar
This is a very simple and basic procedure:
Get a relay and its harness
Harness Will have 5 connectors
Positive 30 - Connects to your Battery Postive
Ground 85 - to any ground source on the car
Activation 86 - Splice it in to your healight's low beam connector on either side
Output 87- Connects go your foglights +, also remeber to ground them as well which u can use the same wire/ground to that as well
Ground Activation or Negative Activation - Not Needed in your case
Please note some relays have different numbering but they are all the same concept
Old Nov 16, 2012 | 11:20 AM
PERFECT!!!! Thanks man!!!
Old Nov 16, 2012 | 09:38 PM
SunburstSS's Avatar
No problem at all bro....Lemme know if you have any other questions
