Help on Interceptor
Old Mar 7, 2007 | 02:06 PM
NKs07CobaltSS's Avatar
Help on Interceptor
I just installed my interceptor gauge and it works great. my question is about the analog wires that are on either side of the power wire did anyone hook them up to anything or are they not important.
2nd what is the most important things to monitor with this and please give me a description of what it monitors and Why its important to monitor. I'm still working on figuring out what all the things on it mean.
also have a question about the wideband i 'm planning on installing one soon. where in the firewall is the easiest to run the wires. any help i can get is appriciated the wideband looks harder to install than the Interceptor was.
Old Mar 7, 2007 | 03:11 PM
BooSSted's Avatar
The analog wire are only used if you want to hook up a wibeband or something else to them. They don't need to be hooked up otherwise.
The main things I watch on mine are Manifold PSI and Knock Retard. The Manifold PSI just a Boost Guage and the Knock Retard tells you if your engine is experiencing knock, therefore retarding the timing to prevent bad **** from happening, haha.
Old Mar 7, 2007 | 03:17 PM
cobi's Avatar
there is a grommet just below the steering shaft where you can run the WB wiring, and I would monitor knock for sure and maybe IAT2 for the second option unless you took your stock boost gauge out.
Old Mar 7, 2007 | 03:18 PM
Kaisoboy's Avatar
HP and knock retard for the most part and sometimes injector pulse.
Old Mar 7, 2007 | 03:25 PM
SKDR112888's Avatar
I use coolant temp, IAT2 retard knock and the other one I change all the time,
Old Mar 7, 2007 | 03:32 PM
an0malous's Avatar
Coolant temp, Knock retard, IAT2, and the 4th changes. sometimes trims, sometimes HP,
dual interceptors ftw!
Old Mar 7, 2007 | 05:08 PM
thanks for the tip on the Wideband wiring! Knock should stay at 0.0 correct!
Ya i shouldv'e got the dual but already had the single ordered before i knew they came in a dual!
Last edited by NKs07CobaltSS; Mar 7, 2007 at 05:08 PM. Reason: Automerged Doublepost
Old Mar 8, 2007 | 07:20 PM
EmperorJJ1's Avatar
couldnt you just use the dic for coolant temp?
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
bustaSS
Sep 3, 2015 09:33 PM
