help needed speakers wont work
Old Jan 23, 2011 | 07:31 PM
Ting-ting's Avatar
so i just installed my new screen its a pionner avh-p4000 it turns on and all that but i have no sound at all from it.i wired it up exactly how i did my old pionner hu but idk why it wont work
everything is connected except this stuff
orange ill wire
purple reverse gear signal
and i dont have a antenna wire in it
any help would be nice
Old Jan 23, 2011 | 07:34 PM
Ting-ting's Avatar
oh and there was a weird green ish colored wire i also didnt know what to hook up to so i left it
Old Jan 23, 2011 | 07:35 PM
padlock's Avatar
is the blue wire off the HU harness connected to the pink one on the car's harness??
just had a similar issue as you and that solved it for me
Old Jan 23, 2011 | 07:36 PM
Ting-ting's Avatar
yeah i have it tapped into the pink wire
Old Jan 23, 2011 | 08:46 PM
Ting-ting's Avatar
does anyone have a pic of the metra harness so i can check colors
Old Jan 23, 2011 | 09:13 PM
padlock's Avatar
its the 70-2104 harness your using right? thats what i used and if you did, just google image it
Old Jan 23, 2011 | 09:29 PM
Ting-ting's Avatar
2103 is what I have
Old Jan 23, 2011 | 11:51 PM
Ting-ting's Avatar
i even installed my old hu and it works so idk wtf is going on
Old Jan 24, 2011 | 01:40 AM
Ting-ting's Avatar
so mad lol
so i messed with it more and noticed below
when the avh-p4000 is plugged in my amp does not turn on but when i plug in my other hu my amp does come on but there both wire the same??
i researched what i could on this i noticed in a thread someone with the same hu said that they had to wire the yellow wire to the red and red to the yellow? currently i have yellow-yellow red-red
Old Jan 24, 2011 | 01:57 AM
EmperorJJ1's Avatar
try unconnecting the remote on the harness and the remote on the amp and touching them to ur red acc
Old Jan 24, 2011 | 02:00 AM
Ting-ting's Avatar
i did that and my hu started smoking lol
Old Jan 24, 2011 | 02:02 AM
EmperorJJ1's Avatar
oh ****..
u sure u did it right? u disconnected the remote coming from the radio and connected the red acc to the remote on the metra harness and the remote for your aftermarket amp?
Old Jan 24, 2011 | 02:06 AM
Ting-ting's Avatar
i took the blue/white wire from the pioneer harness and connected it to the red wire that i tapped to my wiper blades
i really wish there was a picture of a harness thats acctually wired right to look at as a guide
Old Jan 24, 2011 | 02:21 AM
exiged's Avatar
Old Jan 24, 2011 | 02:23 AM
EmperorJJ1's Avatar
does ur hu still turn on?
Old Jan 24, 2011 | 02:29 AM
Ting-ting's Avatar
yeah it still comes on but just no sound at all and my amp wont turn on but if i put in my other hu which is wired the same it does
Old Jan 24, 2011 | 02:32 AM
EmperorJJ1's Avatar
ok what color is the stock wire that corresponds with the blue white remote wire on the metra harness?
Old Jan 24, 2011 | 02:33 AM
Ting-ting's Avatar
pink on the factory harness
then on the pioneer harness the only blue wire is a solid blue and on metra its a blue/white
Old Jan 24, 2011 | 02:42 AM
Ting-ting's Avatar
this is the harness layout to the pioneer hu its on pic 2
http://www.pioneerelectronics.com/St...Manual0123.pdf
Old Jan 24, 2011 | 02:45 AM
EmperorJJ1's Avatar
right it shows a blue/white...
try connecting acc to the blue white in the metra harness with the pioneer blue disconnected and see if it turns on. I have a feeling the remote out on the P4000 was busted before and defiantly busted now
Old Jan 24, 2011 | 02:48 AM
Ting-ting's Avatar
ok ill try and if it is busted on the pioneer then what??
also i got this schosche interface kit that says it works for are car i figured id try it so im using it now idk if that has anything to do with it.ill take a pic
the acc is red or yellow haha??
Old Jan 24, 2011 | 02:49 AM
EmperorJJ1's Avatar
red
Old Jan 24, 2011 | 02:50 AM
Ting-ting's Avatar
ill brb
do you want me to leave the red connected the the radio as well or just the blue wire
Old Jan 24, 2011 | 02:58 AM
Ting-ting's Avatar
Ok I undid the red so the radio red wasn't connected to the red I hard wired
So I took the red from the wiped blade andi connected it to just the remote on the metras harness and yes the amp turns on but since I don't have the red connected to the red on my hu my radio stayed off...so now what are my options
EmperorJJ1's Avatar
both... u need the radio to stay on
