help with steering wheel radio controls
ok i got a 07 LS im getting a leather 07 wheel with radio controls. what do i need to make them work.
Plug them in.
thats it? no need for a differnt wire harness??
The steering wheel should have the harness for the buttons included. You pop off the airbag of your OEM wheel (Disconnecting it and setting it aside), unscrew the nut for the steering wheel off most of the way (Not completely off... You want it threaded on enough to catch the wheel when you pull it off), disconnect the black connector for the stock wheel from the SIR coil (Clock spring), then yank like a mofo on the stock wheel until it comes loose, then undo the rest of the steering wheel nut and remove the steering wheel.
Put the new wheel on, plug in everything, tighten down that nut, reconnect the airbag and then drive to the dealership to have them turn on cruise (Your audio controls should work already). |
well its more the just that for cruise to be turned on
Originally Posted by XgunsmokeX
(Post 4748207)
If the dealership looks at you funny, just insist on it. Mine didn't believe it would work until they test drove it. :lol: |
and how di i tell if i have thisgrey wire in pin61???
info on pin 61???? plus id need to buy cruise controls with DIC. im just getting wheel with radio. prev own keep DIC button/cruise
(Post 4748283)
(Post 4754230)
Originally Posted by Nighthawk243
(Post 4754532)
Pull the BCM connector, find the 61st slot and see if there is a pin in it.
You're going to have to reword that. |
(Post 4756863)
and BCM is where? the wheel i am getting only come with radio controls, the first owner keep the DIC so he could use them
All you have to focus on for the audio controls is the connector for the back of the radio if they dont' work when you plug them in. |
waht???? thought u said theyd work? lol ugh. well my buddy gets me parts at cost so i might get cruise buttons if i know i got pin 61
(Post 4757038)
i got a base 07 only really got wheel cuz it leather and was 38 shipped from another member
also i plan on hookin up a sub can i just wire up the steerin wheel plug then?? |
(Post 4757083)
also i plan on hookin up a sub can i just wire up the steerin wheel plug then?? I personally tapped the LOC into the rear speakers when I added a sub into my old G5. It did pretty well. |
