help with steering wheel radio controls
Old Mar 7, 2010 | 11:32 AM
XgunsmokeX's Avatar
ok i got a 07 LS im getting a leather 07 wheel with radio controls. what do i need to make them work.
Old Mar 7, 2010 | 08:46 PM
NCC-2000's Avatar
Plug them in.
Old Mar 8, 2010 | 03:23 PM
XgunsmokeX's Avatar
thats it? no need for a differnt wire harness??
Old Mar 8, 2010 | 06:47 PM
Nighthawk243's Avatar
The steering wheel should have the harness for the buttons included. You pop off the airbag of your OEM wheel (Disconnecting it and setting it aside), unscrew the nut for the steering wheel off most of the way (Not completely off... You want it threaded on enough to catch the wheel when you pull it off), disconnect the black connector for the stock wheel from the SIR coil (Clock spring), then yank like a **** on the stock wheel until it comes loose, then undo the rest of the steering wheel nut and remove the steering wheel.
Put the new wheel on, plug in everything, tighten down that nut, reconnect the airbag and then drive to the dealership to have them turn on cruise (Your audio controls should work already).
Old Mar 8, 2010 | 06:52 PM
XgunsmokeX's Avatar
well its more the just that for cruise to be turned on
Old Mar 8, 2010 | 07:07 PM
As long as you have a grey wire in Pin61 of the BCM, then yes, that is all you need to do. There is a setting in the computer that is turned off in cars that didn't come with cruise from the factory. All you have to do is pay them about an hours worth of labor to pop the Tech II in, enable cruise, then take it for a quick test drive to make sure it works.
If the dealership looks at you funny, just insist on it. Mine didn't believe it would work until they test drove it.
Old Mar 8, 2010 | 07:12 PM
XgunsmokeX's Avatar
and how di i tell if i have thisgrey wire in pin61???
Old Mar 10, 2010 | 08:49 PM
XgunsmokeX's Avatar
info on pin 61???? plus id need to buy cruise controls with DIC. im just getting wheel with radio. prev own keep DIC button/cruise
Old Mar 10, 2010 | 10:41 PM
Pull the BCM connector, find the 61st slot and see if there is a pin in it.
You're going to have to reword that.
Last edited by Nighthawk243; Mar 10, 2010 at 10:41 PM. Reason: Automerged Doublepost
Old Mar 11, 2010 | 06:06 PM
XgunsmokeX's Avatar
and BCM is where? the wheel i am getting only come with radio controls, the first owner keep the DIC so he could use them
Old Mar 11, 2010 | 07:14 PM
If you don't have the cruise buttons, don't worry about the BCM pin yet unless you get them.
All you have to focus on for the audio controls is the connector for the back of the radio if they dont' work when you plug them in.
Old Mar 11, 2010 | 07:25 PM
XgunsmokeX's Avatar
waht???? thought u said theyd work? lol ugh. well my buddy gets me parts at cost so i might get cruise buttons if i know i got pin 61
Old Mar 11, 2010 | 07:33 PM
I'm not sure what version of the Cobalt you have. Most are wired for it, but if you have the ghetto base/ls model, it may not be wired up for it. If you have MP3 capability on your HU, it should be prewired.
Old Mar 11, 2010 | 08:23 PM
XgunsmokeX's Avatar
i got a base 07 only really got wheel cuz it leather and was 38 shipped from another member
also i plan on hookin up a sub can i just wire up the steerin wheel plug then??
Last edited by XgunsmokeX; Mar 11, 2010 at 08:23 PM. Reason: Automerged Doublepost
Old Mar 11, 2010 | 08:31 PM
If you need to run the audio control wiring, you can do that whenever. It and the subs are independent, so it is a whenever you feel like.
I personally tapped the LOC into the rear speakers when I added a sub into my old G5. It did pretty well.
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
agentirons
Oct 16, 2015 02:11 AM
TedSS
26
Oct 10, 2015 04:30 PM
