Help Sub into Trunk (56K beware!!)
Hey everyone my friend just gave me a sub today its a 12inch P1 punch rockford sealed in a box but problem is that the box does not want to fit into the trunk whatsoever so i have turned to trusty community of cobaltss.net for some advice and help. I attached some pics in here to give you a jisk idea. Thanks.
the only way I can think of is the mesh has to come off so you can break down the box...then staple gun the mesh back on when you assemble it in the trunk...other than that Im not a big help
Originally Posted by Tung
care to explain? if I do take it appart that means i would be trying to put it back together while in my trunk
Originally Posted by kingg5
how do u figure hes screwed...its to big to fit through the openings...its not to big to fit in the trunk.
Originally Posted by joeworkstoohard
most pre-made boxes are just glued together particle board or fibre board., it's pretty hard to take that apart neatly
http://www.mitekfactoryoutlet.com/pr...V-SQ&colorid=0
Nevermind my box is 15 1/4" tall and internal volume is 3.0cu-in...thats new by me 1.25 is what mine is recomended...hrrrrrrrrrm
here's wut u can do. I have a ****** huge box and it was so a bitch to get in. First off that black plastic on the side of the trunk where the latch for the trunk to latch on can be removed by simply pulling up on it towards the sky. Then you can take off the latch with a rachet. See if you box will go in after that. The box might be too long for it to go in so to help out you can remove the carpet and spare tire and what not to get it in. Then you put everything back in like I had to do. You're absolute best bet would probably be to take out the top of the rear seats. here's the link to do so
https://www.cobaltss.net/forums/show...ht=remove+seat
ounce you have them out it will probably be alot easier.
HAHAHAHA great minds think alike! You beat me to it by like a second LOL
wow im gonna try that tomorrow when theres daylight thanks impulse and boosted
