Hid help fast pls!!!!!!!
Old Jan 27, 2011 | 05:03 PM
09Sp0rt's Avatar
Im trying to install my relay and im trying to connect the red wire on the relay to the (+) pole thing on the fuse box and have no idea how to do so... someone please help im looking at mkulreys how to on it but it doesnt say clear...
Old Jan 27, 2011 | 05:14 PM
royce777's Avatar
take a 10m(i think) and unscrew it and put the connector around where the threads are and screw it back on. well of course you have to take the red cap and the fuze box cover offf!!
Old Jan 27, 2011 | 05:15 PM
padlock's Avatar
^this.. or take a pliers and twist it off.. it comes right off
Old Jan 27, 2011 | 05:21 PM
royce777's Avatar
no pliers it will muff it up
Old Jan 27, 2011 | 05:22 PM
09Sp0rt's Avatar
lol ok i got that off, now i just have to throw the hid bulbs in my headlights.......... but the bulb is being stubborn and wont go in all the way.... i think there is like a red rubber thing around the entire edge of the hid bulb. do i just push real hard and it will pop in???? lol
Old Jan 27, 2011 | 05:30 PM
royce777's Avatar
dont push hard. if there was a plastic cap over the bulb then there should be a rubber thing around the base of the bulb. i will get a pic. but pull it off and it it will look the same as the stock bulb there should be the blue seal thing. then just push it easily dont wanna break it and turn it to lock
Old Jan 27, 2011 | 05:35 PM
royce777's Avatar
^dont know why pic is so small but you can click and it should show you big size
Old Jan 27, 2011 | 05:36 PM
09Sp0rt's Avatar
thank you, i got that far, but the hid bulb is not going into the headlight...... dunno why
Old Jan 27, 2011 | 05:38 PM
royce777's Avatar
it only goes in so bar. you push it in and twist n turn. you have that sealing black cap off that back? lol
Old Jan 27, 2011 | 05:41 PM
09Sp0rt's Avatar
yeaqh lol mine looks just ike yours in the pic, the one on the right... but the red seal thing like in the pic i have that too, its just not going in the headlight to seal it correctly... and i dont want to push too hard and break the bulb
Old Jan 27, 2011 | 05:45 PM
royce777's Avatar
yeah on your headlight. on the back theres that black plastic ( not rubber) that goes on once the bulb is on. did you remove that? and you sure you have 9007 bulbs? send me a pic of the back of th headlight housing and the bulb
Old Jan 27, 2011 | 06:03 PM
09Sp0rt's Avatar
ok lemme take one
Old Jan 27, 2011 | 06:07 PM
padlock's Avatar
there might be little "knubs" you have to trim off the back of the bulb.. but ive only heard of that issue with aftermarket projectors
Old Jan 27, 2011 | 06:08 PM
Erod's Avatar
Moderator Alumni
fast or not does not mean put it in general. moved
Old Jan 27, 2011 | 06:19 PM
09Sp0rt's Avatar
how do i get the bulb inside the headlight... that red sealer is not going in all the way... ami doing something wrong?
Old Jan 27, 2011 | 06:21 PM
royce777's Avatar
those three prongs have a special way they line up lol two are closer together and one is farther
Old Jan 27, 2011 | 06:23 PM
09Sp0rt's Avatar
do i out the bulb in the black plastic thing first then put it in???
Old Jan 27, 2011 | 06:32 PM
09Sp0rt's Avatar
i can get the bulb in the housing now... but how do i get the black plastic piece to hold the builb in securely now....
Old Jan 27, 2011 | 06:35 PM
padlock's Avatar
mike should know all these questions
Old Jan 27, 2011 | 07:10 PM
royce777's Avatar
you mean the plastic seal that goeso n after the bulb? you may be required to push slightly
Old Jan 27, 2011 | 07:16 PM
09Sp0rt's Avatar
do i have to put all my wires through the center of the black plastic piece???
Old Jan 27, 2011 | 07:20 PM
BPacak's Avatar
Vtec Rep
how many retards does it take to screw in a light bulb.
im jk someone had to say it.
Old Jan 27, 2011 | 09:49 PM
09Sp0rt's Avatar
ok so i got everything hooked up earlier and only my high beams would come on. I have no idea what was wrong everything to my knowledge was hooked up right any suggestions???
Old Jan 27, 2011 | 11:27 PM
mastersource's Avatar
They make a hid halogen bulb? where did you find it at and which one is low and high?
Old Jan 28, 2011 | 03:15 AM
EmperorJJ1's Avatar
lol ive herd of but never seen that before. hid is low halogen is high. better results then the motorizes high low.
